Ok, so I tried to use low range today and it did not work it is locked in just no low range I have the switch on the dash the low range light was not on either tried forward and backwards both no luck.Can someone give me ideas where to start looking for the problem....thanks in advance
Have you put the truck in neutral while in 4lo. It should kick in put the switch in lo then shift to neutral wait a few seconds and put it back in gear. That should get it done.
You mean while in high 4x4, shift to nuetral, put truck in low-low either by selector or stick then selecting to drive and you'll hear a cluck, your in 4 low. reverse steps to disengage.
Figured it was something easy...LOL I will try it in the morning and let you know ..I have had the truck 5 yrs and never used it I was going to let my 8 yr old boy drive it today and help me figured in low range at least I could catch him if I needed to...THANKS for the input
Shortly after I sold my 99 I got a call from the new owner claiming it was broke and he had to drive 50 miles back to town in low range. He was suitably ashamed when I told him he had to have neutral and the brakes on to shift in or out of low.
