Super chip error code
Old May 19, 2008 | 11:01 AM
smith782134HCP12's Avatar
smith782134HCP12
Hi;
I have an 02, 7.3 X and installed the Super chip yesterday. The throttle is now very responsive which makes me think the timing has advanced which is a positive as I am after the fuel economy. It does have the ability to scan for codes and I am getting two back.
The first “Exhaust Back Pressure Sensor Error.”
Second “Int control mod kam error”
Can anyone tell me what these mean and if they are critical?
Thanks, Smitty.
Old May 19, 2008 | 11:22 AM
smith782134HCP12
I did a search and came up with these.
P0603 PCED Powertrain control module keep alive memory (KAM) error Faulty connection, faulty PCM.
P0470 EP Exhaust pressure sensor Faulty sensor, open signal return, faulty PCM
I am a little new to this. How would you check the PCM or sensor?
Thanks
Old May 19, 2008 | 02:44 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
The first code is related to you tuning your truck, nothing to worry about.
The second code related to the Exhaust backpressure sensor. The EBP tube either needs to be cleaned or the sensor needs to be replaced.
Old May 19, 2008 | 05:42 PM
smith782134HCP12
Error code
Thank you for the reply, your help is much appreciated.
Smitty.
Old May 19, 2008 | 06:13 PM
smith782134HCP12
Also I see that I had the wrong forum! Sorry 'bout that. Heading over the other way!
Old May 20, 2008 | 01:27 AM
Toreador_Diesel
You're in the right forum, but you will get more help if you're in the 7.3 forum.
Biscayne
Vehicles for Sale
Dec 22, 2012 09:46 AM
DieselTrap
May 31, 2012 01:35 PM
Big-Red-89
1997 - 2003 F150
Jul 12, 2011 09:12 PM
F 250 6 liter
Mar 3, 2011 08:44 AM
smith782134HCP12
May 20, 2008 10:02 PM
