help injector question
Old May 17, 2008 | 12:45 AM
808 7.3's Avatar
808 7.3
hey guy and gals in the middle of replacing my injectors and was wondering if i need to remove the rocker arms to take them out
Old May 17, 2008 | 05:47 AM
Kwikkordead's Avatar
Kwikkordead
No you do not need to remove the rocker arms.
You do need to retorque them while you are in there. The bolts tend to work their way loose after time.
20 foot pounds.
Old May 17, 2008 | 06:26 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Correct, no need to remove the rocker arms, but remove the glow plugs before you put the new ones in, then install the new injectors, disconnect the CPS on the crankshaft pulley, install the valve covers loosely, crank for a few seconds to push the oil out of the cylinders, alot of oil falls in there. Thought you might need some handy info if you didnt have it already
Old May 17, 2008 | 08:32 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You can look at this. I think someone said this is like our injectors. Use this for refference because I am not all sure it is the same.
Maybe someone that has done them can tell you more about this. Kris should know if he reads this. clicky here
Old May 17, 2008 | 12:50 PM
808 7.3's Avatar
808 7.3
thanks for to info was in there last night and after i got the valve cover off it looked pretty thight in there mostly in the back right corner under the banks exhaust brake but got the right side done last night and going out there now to do left side and .............wait for it...................DP TUNER
will up date when finished
Old May 19, 2008 | 10:15 AM
miller_feed
Keep us posted. Congrats
Old May 19, 2008 | 10:33 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
What injectors did you go with? I'm assuming that when you ordered your DP you told them about the new/upgraded injectors, yes?
Old May 20, 2008 | 01:41 AM
808 7.3's Avatar
808 7.3
sorry for the slow replay but my laptop crashed on saturday anyway i did tell jody about the injectors. finish installing the injectors and tuner removed six gun and went for test drive and loved it when i came home my wife keep looking at me funny ask her what's up and she said that i have a stupid grin on my face i told her its called a per-ma-grin
tjustice
Apr 21, 2015 05:44 AM
tpc3
Dec 13, 2013 08:36 PM
turbill
Dec 22, 2010 06:59 PM
SAltonS
Dec 18, 2009 08:36 PM
Nathan
Aug 5, 2001 08:58 PM
