Sponsored by: Real Truck
Shift from 1st to 2nd hard
Old May 18, 2008 | 07:12 PM
rockpicker's Avatar
rockpicker
Just got an '01 250 that revs hi when I start out...doesn't shift to 2nd unless I back off the throttle.
I took the VSS out and cleaned it...didn't help. Engine and trans were replaced reman, 20,000 mi ago (guy gave me the reciepts).
I have not looked at any codes yet...got it fairly cheap tho'.
Has anyone had this condition before?
Old May 19, 2008 | 04:06 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Bump - anyone got any clues on this one?
Old May 19, 2008 | 07:37 PM
dew the thunder's Avatar
dew the thunder
Tbirds had a common problem with the 1-2 shift accumulator spring breaking which caused a hard shift into second.
My truck had the kinda same problem which was the rear speed sensor. Speedo wouldn't register till like 20-25 and would slam into second. ABS light was also on full time.
Old May 19, 2008 | 07:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's the symptom of a failed mechanical diode. But this already has a reman, and anyone that is rebuilding transmissions should have known to replace the mechanical diode. Maybe they didn't....
Old May 19, 2008 | 09:55 PM
chromeladyracing's Avatar
chromeladyracing
Mine did the exact same, had to have trans replaced. It didnt shift unless I let off gas. It was the diode problem. It will shift but when it does, it skips second gear and bangs into third. I hope they rebuilt that tranny with the right diode, but that problem sounds all to similar to mine.
Old May 20, 2008 | 07:17 AM
Mark Kovalsky
There is no right diode. The mechanical diode needs to be replaced with a sprag type one way clutch.
Old May 23, 2008 | 08:13 AM
rockpicker's Avatar
rockpicker
What is involved in changing the mechanical diode? And;how much does it cost?
Old May 23, 2008 | 09:41 AM
Mark Kovalsky
It takes a complete rebuild, and also changing many of the hard parts. I don't have a good handle on costs, but it isn't going to be cheap.
Old May 23, 2008 | 11:06 AM
Flipper1940's Avatar
Flipper1940
A man pulled up next to a little girl walking home from school and said "If you get in, I'll give you a lollypop." The girl kept walking. Following along slowly, the man said "Come on and get in the car with me and I'll give you two lolly pops." She kept her eyes on the sidewalk and continued on her way. The man said "Get in with me and I'll give you this whole bag of lollypops!" Finally, the girl turned and said "Look daddy, YOU bought the Ford, YOU ride in it!!!"
Old May 23, 2008 | 01:27 PM
rockpicker's Avatar
rockpicker
Thanks Mark...I bought the truck cheap..$3500 with new engine,body very good...using it for farm stuff.I like it so far.
At work,they have a 2000 2WD 250...on the road work,towing trailers,beaten by the hired men driving....173,500 mi and no major problems.
I was leaning towards a used Chevy till I found this one.
Old May 23, 2008 | 03:17 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Old May 24, 2008 | 05:16 PM
rockpicker's Avatar
rockpicker
I found the trans code # BD 1C16 the engine is 5.4 gas.
Were these the ones with the mechanical diode?
Old May 24, 2008 | 09:08 PM
Mark Kovalsky
No gas engine had a mechanical diode trans. It was only used in the diesel trans in the first half of the 2001 model year.
Old May 24, 2008 | 10:52 PM
krewat's Avatar
krewat
That's good to know, mine is a gasser
But what do they put in place of it?
Old May 25, 2008 | 07:43 AM
Mark Kovalsky
They put the previous model year sprag clutch in place of the mechanical diode.
