kick down adjustment
Old May 18, 2008 | 04:19 PM
crescentwrencher's Avatar
crescentwrencher
what does the a/t kickdown do? and how do i adjust it?
Old May 18, 2008 | 04:23 PM
78f-150Supercab's Avatar
78f-150Supercab
When you push down far enough on the gas pedal, it pushes the kickdown rod lever back, telling the transmission to downshift.
You adjust it by turning the screw on the kickdown lever so the transmission will downshift sooner or later when you step on the gas.
Old May 18, 2008 | 04:32 PM
crescentwrencher
so its not to "precise" huh.
Old May 18, 2008 | 05:38 PM
fasthauler's Avatar
fasthauler
Here is what the Ford Service Manual says, "Check for wide-open carburetor and linkage travel at full throttle. The carburetor full-throttle stop must be contacted by the throttle linkage and there must be a slight amount of movement left in the down shift linkage. Be sure the downshift linkage return spring is connected and the downshift lever returns to a closed position".
That's pretty much it. I have seen some books that say to open the throttle wide open and adjust the downshift linkage so there is 0.60 of free play in the downshift linkage.
I just eyeball it. Open the throttle wide open and adjust the downshift lever so the is still a little free movement in the lever and you should be good to go.
Old May 18, 2008 | 06:01 PM
crescentwrencher
so at WOT the a/t lever should have a .060" gap? how would it work then?
by the way this is on a demon carb, it works pretty much the same way though
Old May 19, 2008 | 01:16 AM
78f-150Supercab
It's basically set so when you push the pedal all the way to the floor, you downshift.
The 0.60" free play means that you can go to full WOT without actually kicking down. If you push the pedal a bit further after WOT, you downshift. He's not saying a 0.60" gap after the pedal is to the floor.... You should reach WOT a little before your pedal bottoms out (or that's how you should adjust it).
When I first got my truck, it had no carpet. When I put carpet in, I had to adjust the kickdown linkage so I didn't have to push the pedal as far down to downshift (because the carpet limited the pedal travel).
M1kem3
Feb 27, 2015 12:19 PM
john fin
Mar 20, 2012 12:34 PM
greenterror
May 14, 2008 02:52 PM
wilbur996
Dec 11, 2006 12:40 PM
