hood wont close
Old May 11, 2008 | 04:07 PM
greenterror's Avatar
greenterror
Cool hood wont close
the cable was just adjusted about 2 months ago is adjusting the cable hard to do?
Old May 11, 2008 | 04:30 PM
fred_79f250's Avatar
fred_79f250
You sure it's not just the lock mechanism stuck? A couple spritz's of wd40?
Old May 11, 2008 | 07:25 PM
sbclemens's Avatar
sbclemens
Try pulling the release to make sure the latch didn't lock. Oil up the latch. Make sure the latch hasn't been bent in. It's easy to do when you're leaning over the engine.
Old May 14, 2008 | 02:24 PM
Darth Baiter's Avatar
Darth Baiter
There's a return spring in the back of the latch that keeps the latch hook open. If it breaks, the hood will not close. The stealership would not sell me the spring - only an entirely new latch mechanism for ~$35. Took the offending spring to the local hardware store, matched it fairly well, and I'm back in business. Looking from above, see if there is a small spring hanging in the back of the unit where it mounts to the cross member.
Old May 14, 2008 | 02:52 PM
Truck Stuff's Avatar
Truck Stuff
When ever that used to happen to me I would just have someone pull it a bunch of times then i would spray it with ALOT of PB Blaster. Worked most of the time.....
jeepdad287
Jul 30, 2017 10:36 AM
parcher440
Oct 6, 2016 12:35 AM
lugnutt
Mar 6, 2009 08:38 PM
phoneman91
Feb 6, 2007 01:36 PM
fordmanSLO
Aug 14, 2001 09:10 AM
