Odometer Altering....
Old May 18, 2008 | 09:37 AM
propaneman's Avatar
propaneman
I drive a 1985 F-250HD 6.9L Diesel T-19 4 Spd Transmission. I just got a new cluster off ebay that has a tach in it and it has lower miles on it than my cluster. Is there anyway to 'turn' the miles up?
Old May 18, 2008 | 11:05 AM
ri_truck_guy's Avatar
ri_truck_guy
There's a small perforated plastic piece in the odometer that holds the digits in place. If you gently remove that piece you can adjust the numbers to whatever you want, then reassemble the odometer. The odometer has to be removed from the cluster. It's been better than a year since I did the same thing to my truck...I don't remember exactly how I got to that plastic piece, but it was very intuitive. It will be very apparent to you.
Old May 18, 2008 | 01:07 PM
uncle.stosh's Avatar
uncle.stosh
If I were you I'd just take the tach and plastic circuit film out of the new cluster and put it in your old one.
You wouldn't have to touch the odometer then.
You are aware that the diesel and gas tachs are different no?
Old May 18, 2008 | 01:59 PM
ri_truck_guy
Good point...the only reason to mess with the odometer is if you're changing from a setup without a trip odometer to one with. That was my situation.
fordka
Ford Truck Parts for Sale
Mar 9, 2014 11:59 AM
Nathan Plemons
Jun 14, 2013 01:56 PM
LSO1123
Jul 22, 2011 04:14 PM
texas fling
Apr 24, 2009 02:57 PM
The Phenom
1997 - 2003 F150
Apr 22, 2004 04:32 PM
