changing rear differential fluid
Old May 18, 2008 | 12:23 PM
big poppa's Avatar
big poppa
I got to do the same, change out the rear more so now, i,m getting some new sneakers for my ride and i did a burnout and one wheel only spinned(right rear). I guess its time for me also to change out the diff-fluid.? Sorry for the hijack.
Old May 18, 2008 | 01:07 PM
Cracker 73's Avatar
Cracker 73
This is perfect time to drill then weld in port for a temp sensor .
Old May 18, 2008 | 07:40 PM
King0581's Avatar
King0581
There is nothing wrong with my diff that I know of. Was just wondering if changing the fluid would help the limited slip.
Old May 18, 2008 | 07:52 PM
big poppa's Avatar
big poppa
I,m waiting also for a reply. bump.
Old May 18, 2008 | 11:18 PM
camodown's Avatar
camodown
I changed my fluid to valvoline Durablend and used just enough friction modifier to stop chatter in turns and the clutch packs grab much better now... I have just turned 220,000 the other day
Old May 18, 2008 | 11:28 PM
white Buffalo's Avatar
white Buffalo
Change the fluid then taker her for a test drive. If she chatters or gives you issues you can add a couple of oz at a time of the friction modifier. Some synthetic fluids do not require the friction modifier but occassionally they need it also (like 1 in 200). If you think you are having issues you can send in an oil analysis of the fluid.
Mike, if we hook up in June I will grab a sample of your rear diff and send it into the lab to see how she is holding up.
Old May 18, 2008 | 11:32 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Not sure what you are waiting for that has not been said. If the diff is fine, then consider it PM. If it isn't it may help. I will say that my fluid was pretty crappy looking but exhibited no symptoms. Just remember the diff is like the tranny with slipping clutches etc that give off residue that was suspended in my old fluid. Having said that, you could run the stock unit to well over 500k and not have a problem. Up to you.
Old May 18, 2008 | 11:35 PM
Tenn01PSD350
If you like Rich. Look forward to meeting you this time.
Old May 18, 2008 | 11:40 PM
white Buffalo
Just got to be careful not to spill any beer in the sample.....
Old May 18, 2008 | 11:48 PM
randomhero1172's Avatar
randomhero1172
I changed mine About 10K after i got the truck. used 5 bottles of mobil 75W1?? (i think 140) full synthetic. Also sanded the pan down and brake cleaned the hell outta it. Put about 12 layers of high heat paint with one layer of a tough enamel on the outside. Used black with orange high heat RTV. Looks pretty cool. get alot of comments on the oozing orange RTV lol So far- so good. I didnt use any friction modifier per the guy at ford looked up VIN and said i dont need any. (no locker or somthing?)
Old May 18, 2008 | 11:49 PM
Tenn01PSD350
Who cares? You know how I feel about OAs anyway. I'm not going to start the hand wringing regardless. When it quits, I will fix it.
Old May 18, 2008 | 11:54 PM
white Buffalo
Just looking for an excuse to drop by & have a few ..
SOrry to
dgruhlke
May 1, 2012 11:22 AM
sarnott140
Mar 17, 2012 07:09 PM
dirtmonkey11
Oct 21, 2009 04:24 PM
jopiel
Dec 28, 2007 01:55 PM
DudesRUs
Jan 13, 2005 01:12 PM
