I have a 2000 F250 4X4 Superduty with open differential reear end. I had the differntial lube changed recently and I believe friction modifier was added along with the synthetic lube. Will this cause any problems?
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly...to answer your question.
Enjoy FTE …..
