Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
snap on ratchet maintenance?
Old May 17, 2008 | 08:21 PM
77f2504by4's Avatar
77f2504by4
Question snap on ratchet maintenance?
i heard somewhere that you are supposed to oil the insides of snap on ratchets. is this true? and if so what is the recomended lubricant?
Old May 17, 2008 | 09:07 PM
Ford_Six's Avatar
Ford_Six
I have used light oil in most of my ratchets, straight 10w lube oil but that's not available to most people.
3in1 should work ok, you don't want to use grease though since it'll dry out and gum it up a bit.
Old May 17, 2008 | 09:55 PM
helifixer's Avatar
helifixer
I always manage to drop mine in the drain pan often enough to keep them oiled.
Old May 17, 2008 | 09:59 PM
lwfox002's Avatar
lwfox002
My Snap-Ons have small screws that you can remove to get to the gears so you can clean them them put a little 3 in 1 in there or any good lite oil.
Old May 18, 2008 | 03:19 PM
77f2504by4's Avatar
77f2504by4
i was wondering about grease, i almost used some, but the 3 in 1 oil worked.
very very true...
i took it apart because it was in a toolbox i got for free and was all rusted up. the 3 in 1 oil free'd it up and now it works perfect!
Old May 19, 2008 | 10:21 PM
orng1's Avatar
orng1
I have used a lot of tools and other than cleaning them with WD40 and a clean rag haven't had any trouble. I have broken the gears but that is just from abuse not lack of maintenance.
Old May 19, 2008 | 11:34 PM
mason55's Avatar
mason55
I use Marvel air tool oil on my ratchets. Never a problem
Old May 19, 2008 | 11:40 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I've never oiled any of my ratchets. Some are still going 30 years later...(the one's we didn't break with a cheater-bar )
Old May 20, 2008 | 12:24 AM
orng1's Avatar
orng1
Yeah that's what will kill the ratchets, cheater bars.
Old May 20, 2008 | 10:22 AM
rbaker6336's Avatar
rbaker6336
Back in the days when I used my ratchets daily I would soak the heads in a can of transmission fluid weekly for a hour or so
The snap-on ratchets I would take apart an clean after a month or so,they don't like dirt or grit
I never used Snap-on ratchets in the field other than 3/4" and 1" drive only in the shop
My other ratchets I would clean about every 6 months
Old May 22, 2008 | 11:51 PM
Bdox's Avatar
Bdox
If they got really grungy I would loosen the screws, wash them in solvent then dip them in ATF or Marvel oil, blow them out and retighten the screws.
Old May 23, 2008 | 08:43 AM
77f2504by4's Avatar
77f2504by4
thanks for the info. with the help of ebay i've gotten 3 more snap on ratchets and i want them to last.
Old Jul 27, 2008 | 08:06 PM
james_joshua's Avatar
james_joshua
Had a "tools safety" presentation taught by an Industrial Rep for Snap-On. They say that if you have a non-sealed ratchet that you should take it apart once a year and lubricate with "light oil", he recommended air tool oil. Otherwise the oil will attract dirt into the gears. If you have a newer sealed ratchet you realy don't have to do anything. The case has a couple of seals and keeps out the dirt and dust.
Old Aug 2, 2008 | 07:57 AM
monckywrench's Avatar
monckywrench
Looks like too much work.
Feel free to send all Snap-On ratchets to me and I'll replace them with late-model Craftsman ratchets. These will break or skip forcing you to exchange them LONG before lubrication is an issue! I'm only here to help.
Old Aug 2, 2008 | 11:33 AM
Bdox's Avatar
Bdox
I think you will have to offer two or more craftsman for a snappy!
