e4od problems
Old May 18, 2008 | 08:26 PM
David85's Avatar
David85
Originally Posted by kcktilt57
yeah thats why i was wondering if it was possible to swap the tail shafts from each other that would take the guess out of it unless i dont understand what he means.
That would involve complete teardown of both transmissions. The tailshaft is practically the last part to come out. If you are able to do that kind of job yourself, than you are better off rebuilding the transmission you have.
Old May 18, 2008 | 08:43 PM
kcktilt57's Avatar
kcktilt57
thanks i was thinking it was a simple swap....sounds like way more than i can handle thanks again
Old May 19, 2008 | 08:21 PM
kcktilt57's Avatar
kcktilt57
well i called local ford dealership today for fun and they told me 1900.00 exchange with torque convertor that comes with 36 month or 100000 mile warenty. what do you think of that ?
Old May 19, 2008 | 08:44 PM
David85's Avatar
David85
I think thats a fair deal considering that its probably one of the safest sources for a properly assembled E4OD. The torque converter is not to be trusted for anything more than a bone stock diesel though. If you ever want to upgrade the engine and add a turbo, you will want a billet torque converter, but if you are staying stock it should be good enough.
Old May 20, 2008 | 12:46 AM
George D.'s Avatar
George D.
Thats a hell of a parts waranty does that include installation?
Old May 20, 2008 | 01:13 AM
David85's Avatar
David85
I doubt it includes labor, but I did hear from other cases here that ford dealers are giving pretty fair deals on E4OD remans. I think the best warranty I ever saw was 5 years/50000 miles. Don't remember who or how much though.
Old May 20, 2008 | 02:31 PM
kcktilt57's Avatar
kcktilt57
no thats doesnt include any labor to r&r it . thats just for reman. tranny with exchange but thats better waranty than any tranny shop will give i believe.
Old May 20, 2008 | 10:20 PM
ford trans tech's Avatar
ford trans tech
the gear is part of the output shaft , but there are several possibilities
it could have a production overrun shaft in it which has teh gear on it or it may have been rebuilt and has an older shaft installed
the only way to swap the shafts is to completely disassemble the transmissions
but there are some other changes that took place in 94 internally so if the 94 has the 94 updated design input hub shaft center support and output shaft you have more swapping to do
Rentaro
Aug 15, 2012 08:16 PM
darickh
1978 - 1996 Big Bronco
26
Sep 2, 2011 05:24 AM
bentcipher
Oct 23, 2010 10:29 PM
bandlgeorge
May 29, 2007 05:04 PM
