Y-Block Four barrel intake
Old Mar 19, 2001 | 07:48 PM
Boss_358's Avatar
Boss_358
I don't know a whole bunch about the Y- block but I am pretty sure I have a four barrel intake manifold for one but am not sure what the year is, what size eingine it was for or what kind of truck/car it came out of. I hope someone here can help me identify the casting number on it so know a little bit more about it. The casting number on the intake is ECZ-9425-B. Below the casting # is 2H9, and below it is a number 3. The number 3 is also on the underside of the intake. It has the firing order on it which is 15486372. The thermostat housing has the number EBV-8594-A with the number 14 below it. The intake is also cast iron along with the thermostat housing. I don't think I have ever seen a thermostat housing weigh almost 2 pounds. All information is appreciated.
78 Ranger 4x4 351C-4V
83 Ranger 302
Old Mar 19, 2001 | 09:06 PM
Nate_64's Avatar
Nate_64
I don't have a complete resource for looking up casting #'s, but the ECZ is for a 312. Maybe someone else could give you a specific year.
You lucky dog.
Nate
1964 F-100 Custom Cab 292 V-8 3 spd
1964 F-100 292 V-8 3 spd
1990 F-150 5.8L
Check out http://clubs.yahoo.com/clubs/fordpickups61to66fseries
Old Mar 19, 2001 | 09:51 PM
Boss_358's Avatar
Boss_358
Thanks for the info Nate. Hopefully I can get the year also. It probably was luck coming across a part like that. I found it with the holley carb still on it with the blue Ford id tag still attached. It took me a while to figure out what it was for because I had never seen that kind of intake runner design before.
83 Ranger 302
Old Mar 19, 2001 | 09:54 PM
Boss_358's Avatar
Boss_358
Mistake. The #3 is above the casting number
83 Ranger 302
Old Mar 31, 2001 | 08:49 PM
Boss_358's Avatar
Boss_358
Alright, I think I figured out what year the intake is but hopefully someone could help me confirm this. The Holley carb that was on the intake has a 284 on the left side looking at the front where the serial numbers are. On the the right side it has the number C3TE-9510-F and below that it has: List 2151-1. I would assume that the C3T stands for 1963 truck. The rest except for the 2151 I have no idea about. Anybody have any Ideas?
83 Ranger 302
Old Mar 31, 2001 | 11:49 PM
Nate_64's Avatar
Nate_64
I checked those numbers on the carb in my parts manual and it looks like it is from a 292 in one of the following trucks:
63 F-B- or N- series 500 or 600, a 63 C-series 550 or 600, or a 64 F- or B- series 600.
I don't know what the 284 or the list # is for.
Nate
1990 F-150 5.8L
Old Apr 26, 2002 | 10:23 AM
babybird1956's Avatar
babybird1956
I think you've got a '57-59 312 1x4bbl intake. Similar to, or exactly, a 1957 Thunderbird. The intake for said bird is a ECZ9425B. I don't know if it was used on other vehicles, but bird parts tend to not be used on other vehicles.
Is this a part you're using, or selling? I've been thinking of changing my bird to the '57 carb, and would use that manifold in doing so.
Old Sep 26, 2002 | 09:48 PM
truks's Avatar
truks
Gene/ Y blocker
Did you sell the manifold or what ?? I need one for a project..block is almost done.!! Gene
Old Sep 27, 2002 | 09:29 AM
286merc's Avatar
286merc
That is the good intake. Used on all 4bbl Y blocks from 57-64. Takes the Holley, Carter AFB (Edlebrock)bolt pattern.
Pre 57 used the ECZ-A.
Old Sep 27, 2002 | 10:34 AM
Boss_358's Avatar
Boss_358
I sold the intake earlier in the year to a guy with a 57 F-100 project, I think it was. Even though I was not advertising it as for sale, he contacted me directly by e-mail and asked if I was willing to sell it. Sorry guys.
Old Oct 1, 2002 | 01:38 AM
pcmenten's Avatar
pcmenten
trozei
40
Sep 12, 2020 09:22 PM
Kalve
13
Oct 11, 2010 09:52 AM
druggles85
Flathead V8 & Flathead 6
Dec 27, 2009 06:14 PM
FTE Ken
21
Jul 19, 2008 05:54 PM
