parts for 272
parts for 272
first let me tell you were im at i have a 1960 ford pickup and it came with a 289 and a 3 speed 9 inch rear and 4:11`s but when i went to rebuild the 289 ifond it was bored .60 over and the pistons were stock size so the cylenders were screwed so im tossing it my dad has a 272 out of his 56 truck and i want it but can i get a triple dueces manifold/cam or a bellhosing for my three speed
thanks for all your help.
parts for 272
Three deuces - yes. They're on ebay all the time. Bellhousing - I wonder.
It took somebody some work to get that Windsor into that truck, so expect that you'll have to undo that work. You might consider shopping around for a replacement for the 289. Don't get me wrong, I like the idea of the 272 (is it really a 292?), but you'll be fixing the clutch linkage, shifter linkage, probably the throttle linkage, the radiator hoses, motor mounts, exhaust, and other stuff. And I'm not sure that you can find a bellhousing that will work with the transmission that came on the 289.
Unless you have the older (pre 1966) 289, A 302 should fit where the 289 was, and a 351W will fit pretty good except for the exhaust pipes needing to be longer. Where I live (Idaho) 302's are easy to come by.
The bellhousing on the early Windsors had 5 bolts. The later Windsors have 6 bolts.
The 289 weighs 450 lbs. vs. the 272 (and 292/312) weighs 625 lbs.
I realize you didn't ask for advice about whether or not to put a 272 in there, but I thought you'd want to consider the work involved.
Best of luck,
parts for 272
0.060" over and stock sized pistons??
It'd knock like a cop with a search warrant,
even if you could keep the rings in the
grooves...
Having owned a '57 F100 with a 289 in it,
you should reconsider putting a 302 or
another 289 in there, as the bell housing
mounts have probably been cut out to get
the 289 and tranny into it...
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6, That blowed up real good...
'01 ZX2 (No Mods yet)
grooves...
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
Jolly Roger Joe
11-07-2016 10:35 PM
Connecticut Calvin
05-26-2015 06:53 PM
dyoungen
10-11-2012 03:15 PM
