Sponsored by: Real Truck
Rubbbing Leaf Springs
Old May 14, 2008 | 07:39 PM
jaynalbu's Avatar
jaynalbu
Hello all,
When I bought my truck it had 32's or 32's cant remember. I put wider and bigger 35's on and now it is rubbing the leaf springs. Any ideas on how to prevent this. Please dont tell me not to turn so far!!
Thanks
Jason
Old May 14, 2008 | 07:51 PM
brwolfjr's Avatar
brwolfjr
More info on the truck would help - you may just have to live with it or get wheels with a different offset. I have 295's and I rub only on hard left turns.
Old May 14, 2008 | 08:28 PM
jaynalbu's Avatar
jaynalbu
1997 F350 with 35's Small lift in front to level the 4" in the back. DOes this help
Old May 14, 2008 | 09:05 PM
6.0superduty's Avatar
6.0superduty
Are you still running the stock rims? If not, what is the backspacing of the rims you have? I think for that year superduty your offset should be somewhere arond 4.5". I have a leveling kit and 35" Mud Grapplers on aftermarket rims and have never had the tires rub the leafs.
Kyle
Old May 14, 2008 | 09:34 PM
high ho silver's Avatar
high ho silver
If you are just trying to keep it from rubbing the leafs, then adjust the bump stops. It will not limit your turning radius any more than it already is but will keep from ruining your tires. I welded some more meat to my stops and then just ground down until I got about 1/4 inch between tire and leaf .
Old May 14, 2008 | 09:43 PM
jaynalbu's Avatar
jaynalbu
Leaf springs
Kyle
I think they are the factory. Here is a picture. You tell me?
Thanks
Jason
<a href="http://s256.photobucket.com/albums/hh176/jaynalbu/?action=view&current=085.jpg" target="_blank"><img src="http://i256.photobucket.com/albums/hh176/jaynalbu/085.jpg" border="0" alt="Photobucket"></a>
Old May 14, 2008 | 09:48 PM
high ho silver
Nope not factory
Old May 14, 2008 | 09:50 PM
jaynalbu's Avatar
jaynalbu
Then I have no idea about the specs. I will look up on here and try to figure it out.
Thanks
Old May 14, 2008 | 10:08 PM
aldridgec's Avatar
aldridgec
Regardless of the fix, nice pic!
I would have to say that if you want to "fix" the problem you will have to decrease the backspacing on the tires a little. I like the idea of fixing the turn stop as suggested above. Cheapest way to go if you have access to a welder!
Otherwise you will be buying four different wheels, or a coil conversion. Does it seem to be limiting your turning ability any? Rubbing badly or just barely?
Old May 14, 2008 | 10:15 PM
jaynalbu's Avatar
jaynalbu
Thanks. Nice truck to huh?!?! Yeah it rubs really hard if I try to turn hard.
Old May 15, 2008 | 01:28 AM
cartmanea's Avatar
cartmanea
I have 8" rims with 4.5" backspace and my 315/75/16s clear the leaf springs by about 1.5".
Old May 15, 2008 | 06:17 AM
texcan's Avatar
texcan
Mine rub if I turn them tight. Only when I 'm trying to manuver in a tight place. I just listen for the rubbing and back off a bit. Hasn't been a problem at all. Just pay atension and don't worry about it.
