"spout" remove for timing
Old May 13, 2008 | 07:24 PM
BCM_'s Avatar
BCM_
I tried timing my 6 the other day. Nothing worked really. Someone said to pull the "spout". I asked him what is that? He said it was a 2 wire electrical connection that overrides changes in the timing by the computer.
Where do I find that connector? He said it was near the "module". OK where is the "module" and perhaps I will find it. Any color to the wires?
I did mark the 10 degree mark with nail polish so I could see the mark while timing it. But I need to locate the "spout" or 2 pin connector, any help?
It is on a 96 F150 300 six.
Thanx.
Old May 17, 2008 | 05:05 PM
flipklos's Avatar
flipklos
In the late 80's ford used a "thin film" distributor. it had a small black clip on a lead coming off the distributor. to set timing you pulled the clip and rotated the distributor. once you found your sweet spot (all this was done at idle) you replaced the clip. the clip to my understanding was the bypass for electronic advance. I cant honestly remember if my 96 had one. If so itll be on the wireing harness to the distributor.
Old May 17, 2008 | 05:53 PM
73f100shortbed's Avatar
73f100shortbed
Some are located on inner fender. The last Bronco I timed had it near the master cylinder on fender.
Look for something like this:
Old May 17, 2008 | 08:12 PM
BCM_'s Avatar
BCM_
Hey thanx a bunch, I found that thing right where you said on the fender right by the master cylinder, and the "module"..it looks identical to your picture.
So the idea is to inplug this, start timing it 10 degrees or so, then plug it back in and test drive. Keep doing this pattern, advancing the timing a little bit at a time until just before preignition/knock occurs?
Just want to make sure.
Old May 18, 2008 | 08:54 AM
80broncoman's Avatar
80broncoman
I am not 100% sure but I have been told the procedure is to start the vehicle and warm it up. Shut it off and unplug the spout connecter. Start and set timing. Then shut it off and plug the connecter back in.
I don't know it that is truely required but it works fine when done that way.
Old May 18, 2008 | 02:45 PM
73f100shortbed
With a timing light and spout connector removed set timing to what it calls for, 10 degrees BTDC or whatever manual or sticker under hood says by moving distributor, then lock it down, plug spout connector back and you should be good to go. Also warm up engine like Broncoman says.
Old Sep 15, 2008 | 04:08 PM
short bed 1993's Avatar
short bed 1993
I am a happy camper I found my (spout) THANK YOU!!!73f100shortbed for the pic & All the rest!!!!!!
Old Sep 16, 2008 | 06:19 PM
Heavy_Metal's Avatar
Heavy_Metal
The "spout" connector acts as a switch. You pull it and the computer will not advance or retard timing. When its connected the computer can make it's timing adjustments. It's like pulling off the vacuum advance on an old school distributor when you set the timing.
Old Sep 22, 2008 | 02:45 PM
aksnopro2's Avatar
aksnopro2
93 f150 on driver side front fender wheel well.
MrRogers
Jun 9, 2010 05:58 PM
don2007
Apr 27, 2008 06:05 PM
MMarty
Sep 7, 2006 06:11 AM
roughcreekgang
Electrical Systems/Wiring
Jul 16, 2005 08:29 AM
fishingboy
Nov 1, 2002 07:54 AM
