Base ignition timing 460ci
Old Jul 14, 2005 | 06:17 PM
roughcreekgang's Avatar
roughcreekgang
I thought this would be easier but have run into a wall. The sticker under the hood says the base timing should be 10 degrees BTDC. The sticker also says to disconnect the SPOUT connector before checking timing. Thats my problem, where is the SPOUT connector. I know it is "spark out" and is connected to the distributor control module. Non of my books are any help. There is a 2 wire connector (in-line) by the control module wiring that has a removeable piece that I find (with my meter) just shorts or opens that wire. Could this be it? I am hessitant to open the wire and then find out I blew something in the computer. This is related to a overheating problem that I am trying to track down. I wanted to make sure timing was correct. With everything connected the time looks to be about 25-26 degrees.
Any help would be appreciated.
I will post my cooling problem in the cooling section.
Thanks, roughcreek
Old Jul 14, 2005 | 06:22 PM
roughcreekgang
I should add that this is a 88 F-250, EECIV
Yhanks, roughcreek
Old Jul 15, 2005 | 12:59 PM
Franklin2's Avatar
Franklin2
That's it. All you are doing is taking timing control away from the computer so you can set it mechanically. If you didn't disconnect the spout jumper, then you would move the timing, and the computer would instantly move it back where it was, till it hit it's limit. That's all you are doing, is setting the mechanical timing in the ballpark, so the computer has enough adjustment room to control it from one end the the scale to the other.
Old Jul 15, 2005 | 01:40 PM
roughcreekgang
Thank you Franklin2, I will check it now, but your explanation of the operation of timing sounds like it would have to be pretty far off to be causing my problem.
Thanks again, appreciate it.
Roughcreek
Old Jul 15, 2005 | 09:46 PM
Franklin2's Avatar
Franklin2
What's the problem?
Old Jul 16, 2005 | 12:03 AM
roughcreekgang
Overheating, I posted it in the cooling section.
Old Jul 16, 2005 | 08:29 AM
Franklin2's Avatar
Franklin2
Overheating only moving down the road, or overheating only around town and sitting idling?
What are the symptoms of overheating? Puking water out the overflow? The temp guage going up too high? The engine starts pinging?
grmtnmn
New Member Introductions
Aug 31, 2015 11:46 PM
bobrpm306
48
Feb 9, 2013 10:18 PM
bnb29
Electrical Systems/Wiring
Apr 24, 2011 03:44 PM
myrangertruck
1983 - 2012 Ranger & B-Series
Sep 1, 2003 10:35 AM
Silver_Bullit
Feb 12, 2003 11:49 PM
