It needs IPR (injection pressure regulator) o-rings. Cheap fix for about $30 from Ford ($15 from international and about an hour if you can have it fixed.
IPR is located on the back of the HPOP down low.
IPR O-Ring Kit (for when IPR valve replacement is not required)
(Ford) F6TZ-9C977-AN (F6TZ-9C977-AA?)
(International) 1825806C92 (1825806C91?)
Thank you ever so much, been to two diesel mechanics.They blame injectors and glow plugs. We knew that was a bunch of hot air.
