Lifter problem
Old May 12, 2008 | 04:47 PM
Metallheadd's Avatar
Metallheadd
Lifter problem
I am having a lifter problem. It started as a tapping noise in the top end. I figured it was due to this truck sitting for a bit before I bought it a month ago. Well the noise would come and go as I drove, but seemed to get better as time went on. Well now it seems to be collasped. The motor now has a slight miss or shake to it and I tried the dollar thing at the tailpipe and it tries to suck it in. What do you guys think should be the next step. I want to build a motor next year, I really didnt want to tear into this thing big time. Any suggestions?
Old May 12, 2008 | 07:32 PM
OldMetal's Avatar
OldMetal
I wouldn't start by blaming a lifter, try to find out which cyclinder is making the noise first and pull the valve cover off to check for a bent push rod, loose rocker or a bad valve spring, if it is a lifter you can always just change it along with any related parts without tearing the engine down but the first thing is to find out what's causing the problem.
68f10059
Oct 4, 2013 07:52 AM
The Fool On Th Hill
21
Feb 25, 2012 06:33 PM
1998F250SC
1997 - 2003 F150
Jul 13, 2008 11:29 AM
Jrock909
Feb 3, 2007 10:57 AM
javi2001
19
Jun 1, 2004 08:34 PM
