Gear Shift Indicator
Old May 24, 2008 | 07:46 AM
Gevans17's Avatar
Gevans17
holy crap!
Nice pics of how to pull apart the Expy's dash, but I didnt have to do that to fix mine.
Old Mar 9, 2009 | 12:53 PM
peakay's Avatar
peakay
hey guys,
so what is the fix on this for a 2005 model?
Old Mar 9, 2009 | 03:58 PM
alwaysfords41's Avatar
alwaysfords41
For mine it was a $110 fix for the dealer (parts and labor) - it was there for something else and he offered to do it. I hadn't gotten to it so I had it done. It was not a sticky carriage as I had suspected, it was a broken retrun spring.
Old Jul 29, 2009 | 12:21 AM
bc11's Avatar
bc11
Hi guys, got referred to this thread from mine. My 98 won't go all the way over to park. My daughter has it down in Texas now but when she gets back this weekend I'll look up under the dash to check things out. It just acts like something is jammed keeping it from moving that last little bit to park. It runs up and down through the gears all right down below park.
My question is if I take a can of silicone spray lube with a 6" tube on the nozzle, can I point it up in there and spray and try to lube the slide and would that maybe work or would I end up filling up the inside of the instrument cluster with the oily spray? Thanks.
Old Jul 29, 2009 | 12:28 AM
alloro's Avatar
alloro
More likely than not.
Old Jul 31, 2009 | 06:29 PM
mtuck's Avatar
mtuck
I have an '01 and when mine went out, I had to lay down on the floor and look up under the dash. Look around the steering column, you are looking for a small white square piece of plastic that has a black turning wheel and a small orange cable running through it. I think it was easiest to do this witht the engine off and the car in 1st gear. On mine, the small white plastic had a broken area. I unhooked the cable and then unscrewed the white bracket. A little super glue and about 10 minutes and you should be good to go. Re install and hook it all back up.
~Tucker
joestratton1
Feb 16, 2014 06:51 PM
Jrakar
1997 - 2003 F150
Oct 8, 2010 01:10 PM
WhoKnows
16
Feb 21, 2008 09:31 PM
workingdog
Jun 15, 2006 04:28 PM
devil421
May 31, 2005 07:32 PM
