Sponsored by: Auxito
Shift Lever indicator not working
Old Mar 12, 2010 | 04:46 PM
Jrakar's Avatar
Jrakar
1998 F-150. Going down the highway this afternoon and noticed that the orange indicator on the dash said I had the truck in "2". Took my foot off the gas and moved the sifter up one to "D". To my suprise when I put my foot back on the gas I got nothing. On the dash it was in "D" but really it felt like it was in netural. I move it back to "2" and got to my destation. Went to put in "P" but the indicator was no going no futher than "R" and the truck was in park.
It appears that something is broke that moves that indicator. Any ideas?
Old Mar 12, 2010 | 05:20 PM
cogden's Avatar
cogden
It sounds like your gearshift indicator is out of alignment. The indicator is linked to the shifter by a little cable, similar to a bicycle brake cable.
The alignment of the indicator can be adjusted by tightening or loosening the mounting nut on the cable.
Here's a link with more information:
Ford F150 Gear Shift Indicator Adjustment .: Ford Truck Articles
Hope it helps!
Old Mar 12, 2010 | 07:41 PM
Jrakar's Avatar
Jrakar
Smile Right on
Thanks- the white plastic bracket was broke. It holds the adjustment wheel in place. I zipped tied it back together and seems to be working. Called a dealership and they want $45 for the part. Going to shop around and see if I can find it cheeper.
Old Mar 13, 2010 | 04:07 AM
whitefordexplorer's Avatar
whitefordexplorer
this is where junkyrads come in handy, 99.99% of the time small parts like this are still in the vehicles when you go to look for them, and removing them may be a pain, but it will cost you about a buck, compared to $45, thats a damn good deal
Old Jun 25, 2010 | 04:22 PM
GoSkins's Avatar
GoSkins
sweet! I just did a search cause my 02 is doing EXACTLY the same thing. Thanks for the info, I'm gonna go check it out when the sun goes down a little. Very hot today!
Old Oct 8, 2010 | 01:10 PM
TJ272's Avatar
TJ272
Just what I've been needing, too. . .
I have an 02 Super Crew with the same gear shift indicator problem. Thanks for the info, and I'll be checking on mine this evening and weekend to see if I can repair it.
bduemig
Jun 8, 2014 10:56 PM
Wicked Endings
Jun 22, 2013 10:21 PM
Gordon Grooms
Electrical Systems/Wiring
Dec 4, 2012 05:40 PM
skeith5
Mar 29, 2011 06:31 AM
Waff78
1997 - 2003 F150
Jan 18, 2011 01:21 PM
