Gear shift selector not lining up properly
Old May 30, 2005 | 01:39 PM
devil421's Avatar
devil421
99 Explorer Sport 4x4 SOHC Auto 82K. This truck is now starting to become maintenance intensive. Might to time to trade in. Oh well...anyway.
I took a short drive today (20 miles) and when I parked, the gear selector now does not line up with its selected gear. For example, P now shows as between P and R. D lines up with 2. N lines up with...blah blah ad nausem. Basically the orange indicator is one spot to the right of where it SHOULD be. This just happened during this drive?
What should I be looking for? Usual fix?
Thanks!
Old May 30, 2005 | 03:22 PM
don96exp's Avatar
don96exp
on most fords the gear shift indicator is usually operated by a cable that is attached to the steering column under the dash and is adjustable. Try looking under the dash for the cable and adjust it as necessary.
Old May 30, 2005 | 03:34 PM
devil421's Avatar
devil421
Thanks for the reply! It turns out that the adjustment wheel bracket is broken and its a real PITA to replace. I might have to have a dealer take care of it. Fortunately it doesnt affect the drivability.
Old May 31, 2005 | 07:30 AM
mason's Avatar
mason
I replaced one on a Mercury Villager van. Wasn't too difficult but be sure to disconnect the battery before working around the steering column.
Mason
Old May 31, 2005 | 07:32 PM
devil421's Avatar
devil421
I installed the new clip tonite and everything is perfect!
armydude
Aug 15, 2015 07:11 PM
Drunken_Unicorn
Jul 12, 2015 09:11 PM
danlee
Sep 23, 2013 08:02 PM
wildstang
Vermont Chapter
Jul 14, 2013 04:21 PM
