idle problems on start up???
Old May 11, 2008 | 03:30 PM
Pitchfork87's Avatar
Pitchfork87
i have a 94 powerstroke. when i start it up the engine kind of chugs for about 4 or 5 seconds and then idles. any advice would be greatly appreciated
Old May 11, 2008 | 04:28 PM
Cuda_jim's Avatar
Cuda_jim
Is it a Powerstroke or a Turbo IDI? 94 or 94.5 is the difference.
The IDI will have Ford on the engine cover.
A couple bad glow plugs may cause it to run rough at startup.
IS the check engine light on?
Old May 11, 2008 | 04:49 PM
Pitchfork87
its a 94.5 powerstroke. and no the check engine light is not illuminated
Old May 11, 2008 | 05:15 PM
tjbeggs's Avatar
tjbeggs
does it do it with the engine hot or cold? Should be a manual trans, is that correct?
Old May 11, 2008 | 05:43 PM
Pitchfork87
it is a manual. and it does do it when hot but not as bad when call.
Old May 11, 2008 | 05:46 PM
tjbeggs's Avatar
tjbeggs
How many miles on the oil?
Old May 11, 2008 | 06:14 PM
Pitchfork87
just put new oil about 750 miles ago
Old May 11, 2008 | 06:46 PM
tjbeggs's Avatar
tjbeggs
well like Jim said could be a glow plug issue. Could also be a dirty IPR. Try starting the truck with the ICP sensor unplugged.
Iron Port
1978 - 1996 Big Bronco
Jun 26, 2017 03:35 AM
DAT2109
Apr 4, 2012 09:12 AM
EMC V10 X
Modular V10 (6.8l)
Dec 31, 2010 06:39 PM
Truckerteacher
Oct 29, 2005 10:47 PM
