6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
75-80mph issues
Old May 10, 2008 | 08:52 PM
99SevenPoint3's Avatar
99SevenPoint3
75-80mph issues
Hey guys i just had a question if any one has had an issue when they reach the 75-80 mph limit ...from what i understand its like a jerking/shaking motion. This is a vechile of a family member so i haven't actually been inside the truck when this has happened. He told me that it felt like the jerking/shaking motion recently stopped. So my question is this a common issue or is/was this bad fuel....sorry for the long post thanks in advance.
Old May 10, 2008 | 09:23 PM
Tater Mash's Avatar
Tater Mash
I too have that issue. For me it appears to happen when I get to 80 mph and am holding at that speed. It seems like the best way to describe it is a hesitation. I keep forgeting to ask my service guy about it when I take it into the shop. It doesnt to it all the time, so I forget to mention it. I will have to make it a point to write it down so I remember to ask on the next visit.
Old May 10, 2008 | 09:26 PM
Boaz66's Avatar
Boaz66
I have not seen this issue in my truck yet. It does sound as if you need to speak to a service advisor and see if this problem is more prevelant.
Old May 10, 2008 | 09:39 PM
SouthTexasDiesel's Avatar
SouthTexasDiesel
Is it an F-450? Because if it is that's the speed limiter.
Old May 10, 2008 | 09:57 PM
kimminau2's Avatar
kimminau2
Definitely sounds like the speed limiter. that is what it will do, however you should not reach it until you get to at least 80. Mine does it at 83. I think on the 450's it is supposed to be limited at 80.
Old May 10, 2008 | 10:02 PM
Tater Mash's Avatar
Tater Mash
Mine is an 08 F-350 DRW I dont believe it is a speed limiter, because she will go faster with no issues. It just seems to do it if I am cruising at 80 and am just in the throttle enough to maintain 80. any faster and it stops doing it, and any slower it does not do it either.
On a side note, how do you get the signature line with all of your truck info? I want to enter all that info so everyone can see what I have?
Old May 11, 2008 | 09:39 AM
kimminau2's Avatar
kimminau2
Go to user cp and follow the links.
Old May 11, 2008 | 10:35 AM
Maxium4x4's Avatar
Maxium4x4
Speed limit is determined by tire rating on the truck.
Old May 11, 2008 | 10:42 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
You need to have 25 posts before you can set up a signature.
Old May 11, 2008 | 12:03 PM
Jay2008's Avatar
Jay2008
Mine did the same thing on occasion for a while but hasn't done it in a while now. I did notice it went into regen shortly after it did it so I assumed it was related. Mine was exactly as you described....just holding 75-80 and accelerate a little to go up a hill and almost felt like an old car backfiring through the carburator.
Old May 11, 2008 | 07:09 PM
99SevenPoint3
Thanks guys for the replys. I forgot to mention it is a 08 F350 DRW. Ill mention it to him about the speed limiter , but from what i am aware the issue has not come up again and i think he has been able to move it past 80mph with no problems. It "went away" as he described it about a week later when he actually was towing.
Old May 11, 2008 | 08:19 PM
Tater Mash's Avatar
Tater Mash
Thanks for the info on the signature line. I will work on posting 19 more times. LOL
Old May 11, 2008 | 08:46 PM
Cass's Avatar
Cass
75-80mph issues
So far, my 08 F-350 DRW does not seem to have any problem like that. Runs fine.
nmband13
1997 - 2003 F150
Feb 23, 2010 06:07 PM
true blue
15
Aug 17, 2006 09:32 AM
pbjohns
Aug 8, 2006 12:49 PM
elite64a
2004 - 2008 F150
13
Feb 2, 2006 11:19 AM
Teroy
Oct 11, 2003 05:09 AM
