Is this normal MPG?
Old Aug 15, 2006 | 08:00 PM
true blue's Avatar
true blue
Is this normal MPG?
14.5 on the highway at 75-80 mph empty.
I sure thought it would do better than that.
Old Aug 15, 2006 | 08:22 PM
1997F-350's Avatar
1997F-350
all depends. gears,tranny and driving habit. slow it down to about 60-65 it will be better. but 14.5 is pretty good.
you could buy a gasser and have half the power and mileage.
Old Aug 15, 2006 | 08:38 PM
true blue's Avatar
true blue
I think I have 4:10 gears, not really sure.
Old Aug 15, 2006 | 09:45 PM
ltfox's Avatar
ltfox
For 4:10 and driving 75-80 thats proably normal. If I keep it under 70 I will get around 17-18 mpg.
Old Aug 15, 2006 | 09:47 PM
1997F-350's Avatar
1997F-350
35 4.10
39 3.55
c5 4.10ls
c9 3.55ls
axle code on door jamb sticker.
Old Aug 15, 2006 | 10:16 PM
true blue's Avatar
true blue
Cool! I have a 4:10 LS. Not so good for mpg though.
Old Aug 16, 2006 | 12:02 AM
Dick7.3's Avatar
Dick7.3
I got a c9
Old Aug 16, 2006 | 06:00 AM
Cuda_jim's Avatar
Cuda_jim
I have the same truck (96 tho) same milage too. keep the rpm under 2000 for better mileage (yah! right)
Old Aug 16, 2006 | 06:08 AM
utahcrew's Avatar
utahcrew
True Blue, I have a 1997, auto, cc, 4x4 and I get between 16-18 mpg on the free way if I stay at 70mph. (2200 rpm). I also run 4.10 gears, and 285/75r16. try and keep the rpm's down. With the cost of fuel it's a real insentive.
Old Aug 16, 2006 | 06:17 AM
true blue's Avatar
true blue
I have to make the return trip home. I will let you know how it goes with slower speeds.
Old Aug 16, 2006 | 09:31 AM
1969fordguy's Avatar
1969fordguy
My best ever MPG was 18. The RPMs were steady at 2000 and there was maybe 600lbs. in the back. Kinda slow going with the 4.10 gears but not too bad. This is after a bunch of mods, before any mods it was about 3 MPG less. Normal for me is around 16MPG.
Old Aug 16, 2006 | 11:46 AM
strokenalong's Avatar
strokenalong
Talking
I just ran a 800 mile trip at 65-70 MPH w/ my short trailer (light load) and averaged 16 MPG. Usually get 18 MPG when not towing.
Old Aug 16, 2006 | 03:23 PM
peoffice's Avatar
peoffice
My diffential code not on list
My rear end code says D5. I'm thinking that this means it's a 4.11 but not limited slip. Anyone know the reality of it.
Old Aug 17, 2006 | 04:36 AM
Flea's Avatar
Flea
I know Tire pressure comes into play as well. What are you guys running your pressure at. The door jam says 55psi for front for me and 80 in back at so many Kilo Pascals, which I don't know how to convert.
I have 3.55 w/o LS and I get 14 MPG with 42psi all around.
Maybe I should stiffen them up a bit.
I am thinking I am also having injector problems.
I am using Diesel Power and Power Services, Kleen.
Any recommendations?
Old Aug 17, 2006 | 05:34 AM
BEECHBM69's Avatar
BEECHBM69
42 is way low for the front I would think, you can probably get away with that in the rear with no load (it does ride a lot better). If I'm going on a road trip I run pretty close to the max all the way around. Rides worse, but less hurtful in the wallet area.
Dan
