Shifter problem
Old May 10, 2008 | 08:10 PM
trike1946's Avatar
trike1946
Question Shifter problem
My F350 has a problem with the shifter arm or ? It has been to the stealer 3 times and they don't seem to know what to do. Sometimes when I put it in park it doesn't really go in. It just looks like it and the truck rolls. Sometimes it does not start in park. Sometimes when I put it in drive it is really in drive 2. It is very hard to get it into reverse.
The cable is new. I don't believe there are any adjustments underneath. There must be a problem in the steering column somewhere I would think. The truck has 75k. No mods, just stock. Does anybody have any ideas? Thanks for any help.
Old May 10, 2008 | 08:12 PM
F350-6's Avatar
F350-6
Look at where the lever connects to the column. You have to kind of lay in an awkward position to look up at it, but I believe there are 2 torx head screws that you can tighten up. They've been known to work their way loose.
Old May 11, 2008 | 05:42 AM
trike1946's Avatar
trike1946
Thanks for the reply. Is there anything in there that is adjustable? Or can the arm be bad? What is the connection between the arm I move and the little needle I see in the dash?
Old May 11, 2008 | 06:19 AM
ron's power stroke's Avatar
ron's power stroke
it can be adjusted..just cant remember if it was under the column or by the trans... the top part of this link is for key..half way down is for the shifter...not sure if it will help you or not...but if them screws Chris is talking about are loose..im sure that will fix it..many guy's here found this to be the trouble...
<TABLE cellSpacing=3 cellPadding=0 border=0><TBODY><TR><TD></TD><TD>ShiftLever.pdf </TD></TR></TBODY></TABLE>
Old May 11, 2008 | 07:08 AM
trike1946's Avatar
trike1946
Does the ignition switch come out by pushing in the pin like the older ones? I think it had to be in the on position?
Old May 11, 2008 | 08:10 AM
F350-6's Avatar
F350-6
Yep. That's exactly how it comes out.
Redneckfordf2502002
2009 - 2014 F150
13
May 2, 2015 09:28 PM
teamlx88
Jan 4, 2015 01:40 PM
1fixitman
May 16, 2013 03:50 PM
shaggszgn
Aug 17, 2009 11:25 AM
stepasideman
1978 - 1996 Big Bronco
21
Aug 15, 2006 10:55 PM
