Rear view camera Glitching
Old Feb 1, 2015 | 10:19 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Ok so we have a 2010 F150 4x4 Lariat 5.4L with the 508A package (not sure if it makes a difference) super crew 5.5 bed with the shifter on floor and back up camera in the ford emblem.
The dealership already knows about this and are going to fix it however I want some of y'alls opinion on this.
When you put the truck into reverse it has the back up camera in the rear view mirror come on no problems sometimes but other times it will go whiteish gray colored and static sometimes unless you either tap the shifter (only sometimes helps) or put it in park then reverse again.
The dealership says it is the mirror itself but I am thinking it is in the shifter. The dealership only had the truck a couple days before they sold it so I don't think they were able to diagnose it well. Before I take the truck back to fix the seat I would like some opinions on what you think so I can tell the dealership.
Thanks,
Trav
Old Feb 2, 2015 | 01:26 PM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by Redneckfordf2502002
...The dealership already knows about this and are going to fix it however I want some of y'alls opinion on this.
When you put the truck into reverse it has the back up camera in the rear view mirror come on no problems sometimes but other times it will go whiteish gray colored and static sometimes unless you either tap the shifter (only sometimes helps) or put it in park then reverse again...
I'm glad your dealership is addressing this, Trav. What's the current mileage on your truck? I'll see what I can do to assist.
Crystal
Old Feb 2, 2015 | 09:50 PM
Redneckfordf2502002
59800 miles on it so it is out of warranty but them fixing it was part of the deal.
Also thanks Crystal.
Trav
Old Feb 13, 2015 | 09:58 PM
Redneckfordf2502002
Bump. Dealership still hasn't called us in for anything so curious if I might be able to get any more responses before they do.
Trav
Old Feb 18, 2015 | 05:15 PM
Redneckfordf2502002
Tomorrow (the 19th) we are bringing the truck in to have the seat cover and rear view camera fixed (hopefully on the camera).
Trav
Old Feb 19, 2015 | 08:38 AM
FordService
Official Ford Rep
Trav
Come back and tell us how the visit goes, Trav. If you need help after getting a diagnosis, just let me know.
Crystal
Old Feb 19, 2015 | 05:29 PM
mrrish79's Avatar
mrrish79
Good luck I'd like to know how this goes
Old Feb 19, 2015 | 07:24 PM
Redneckfordf2502002
Well dealership didn't fix it today. They only got to the bottom seat cover.
Took them 4hrs to do that.
Still would be willing to take suggestions that way I can let the dealership know.
Trav
Old Apr 23, 2015 | 08:35 PM
okie72's Avatar
okie72
Did you ever get your backup camera fixed? mine is doing the same thing.
Old Apr 24, 2015 | 03:38 PM
Redneckfordf2502002
No the dealership screwed us by never calling and pretty much ignored us. Typical stealership.
Trav
Old Apr 27, 2015 | 02:00 PM
FordService
Official Ford Rep
What's your truck's model year and mileage, okie72? I'll see what I can do to help your camera see clearly again.
Trav
Is there a different dealership you'd prefer to work with, Trav? You can find some alternate options by entering your ZIP code here: Ford Dealers | Locate a Ford Dealer Near You | Ford.com When you choose one, send a PM my way and I'll escalate this to your regional customer service manager. In your message, please include your full name, best daytime phone number, VIN, current mileage, and servicing dealership info.
Crystal
Old Apr 27, 2015 | 02:08 PM
Redneckfordf2502002
No I am instead probably going to set it up on a bigger screen with navigation externally. It really is a little to small to begin with. Besides that we have yet to use it being I don't really use luxuries that often.
Thanks for the offer though.
Trav
Old Apr 27, 2015 | 04:54 PM
okie72's Avatar
okie72
My truck is a 2010 F150 King Ranch 4x4 with 112000 miles on it. I bought it used about a month ago and of course the backup camera worked fine until I got it home. I have pulled the plug apart to remove the tailgate and sprayed electronic cleaner in it made no difference. I also used splice connectors and spliced new wires around the tailgate plug and it made no improvement so I don't think the problem is in the tailgate plug but I really don't know what else to look at. The truck also has backup sensors and they work fine no problem with them. Any help would be very much appreciated.
Old May 2, 2015 | 09:28 PM
okie72's Avatar
okie72
SuperDutyScaler
Nov 6, 2017 10:00 PM
MIKES 68 F100
Apr 20, 2015 07:46 PM
Nighteyez
1983 - 2012 Ranger & B-Series
May 17, 2009 11:32 AM
Jimbo302
1997 - 2003 F150
Apr 3, 2004 10:50 PM
SPROCKET
Feb 7, 2003 08:31 AM
