Got some more done on the "outline of a 51 F1"
I have been working on my truck this week and got the column in it with the custom column drop I carved up on the mill on it (a venolia aluminum Hemi rod out of my buddys pro mod) and got the steering linkage in it today only 180.00 in U joints. I am going to run a column shifter so I had to cut the shift tube and lower column tube and rotate it about 90 degrees and weld them back together to clear the brake pedal. I forgot, I also got the TCI brake pedal and booster mounted so next week is going to be time to get some brake lines on it and a trans crossmember. I found out if anyone else is going to a MII frontend you can use a granada outer tie rod end and you don't have to use rack extensions.
The darkside has another member
Mike, MPH Racing and fabrication
PapaMatt
43
06-06-2015 05:45 PM
ferguson777
28
03-15-2013 08:41 PM
oldblu
12-31-2011 01:28 PM
Lwlandy
16
10-01-2005 09:25 AM
