Firewall Mounted Brake cylinder positioning
Hi all,
I have a firewall mounted cylinder in my 56 that a previous owner mounted. After driving it for a very short time I quickly noticed that the Brake pedal was completely in the wrong place.
I ended up having to drive by braking with the left foot. The reason being that the brake pedal is quite high up and on the left of the steering column. What this means is that when going from the accelerator to the brake you have to remember to navigate your foot around the steering column, otherwise you do what I did the first time, hit the column with your foot then panic!
So, has anyone got any tips on pedal placement etc. as I would still like to mount on the firewal when I go to Booster system, but I want to make it more driveable, the original was on the right of the column, this would be the best place for it but I just cant see how to mount it to get the pedal there.
Thanks
Lee
Thanks
Lee
Originally Posted by Huntsman
If your booster clears everything under the hood, why don't you take the brake pedal lever loose and modify it to clear the stearing column. It is very common to bend them right/left and up/down depending on you needs.
My master cylinder/booster/brake pedal assy is directly behind the steering column. I have done a bit of reshaping on the pedal arm to bring it out on the right side of the column. I cut off the foot pad, lengthened and reshaped the pedal arm, and rewelded the foot pad.
My truck is an automatic, be it right, or be it wrong, I prefer to use my left foot to brake with.
I would say that if the master cylinder/pedal assy looks good and fits with the engine, etc then redesign the pedal arm and foot pad.
Good luck
Bobby
Good luck
Bobby
on
I owned a street rod years ago where the PO had installed the brake pedal on the left side so I learned to use my left foot on the brake pedal. It was a little confusing at first since my Wrangler had a 5 speed manual and I had to switch from lefty to righty according to which car I was driving. I installed mine on the left side of the column in my 48 because it fit better there. I no longer have the Wrangler so now I'm a "full time" left footed braker. I read somewhere that left footed brakers have a better reaction time. Think about it. All your left foot is doing is sitting there. It makes sense that you might be able to get your left foot on the pedal quicker than taking your right foot off the gas pedal and moving it to the brake pedal...
Vern
Vern
Thats an interesting thought Greatnorthwoods.
I was surprised how quickly I got to grips with left foot braking when I had too. I guess its no different to carting. I have been quite a few times and always seem to just get on with it with not too many mishaps.
I guess its just what you are used to.
I will have a good look at the position of the booster/cylinder and make my mind up on weather to move it, adjust the pedal, or maybe leave as is.
Cheers
Lee
Cheers
Lee
I "automatically" left foot brake auto transmission cars I drive, and left foot brake when racing (have some issues with not hitting the clutch tho, feet too big space too small) since we use the brake more for adding weight to the front wheels and lighten the rear to turn than to slow down we can keep part/full throttle with the right foot.
Originally Posted by fatfenders56
I moved the booster/mc toward the outside to make room for removing valve covers and to access the balance bar and steering box
