advice on elec. fuel pumps?
85 F150, orig. 300/6 with mech. pump, it's now a 95 302HO with surpintine system and I have to have an electric pump.
Problem is I can only get 1/2 tank out of the rear tank before it runs out of gas, and 3/4 of a tank out of the front tank. I've pulled both tanks twice, replaced both "socks" and still have the same problem. The truck is runnin now on a chicken s**t Purolator transformer lookin noisy thing. I tried a Carter 4070 and can't get it to run from a standstill. I have a new Carter AFB I've adjusted every which way but loose, bigger jets, metering rods etc.
Real pain this is. I guess I need a pump that will suck Moby ##### thru a keyhole.
Thanks,
Moe
Houston
>pump in each tank,if not
>are the "socks" down far
>enough in the tanks?They should
>be close to touching bottom.Good
>luck windsor
No "in tank" pumps, the orig. 300/6 used a mechanical pump and it had a "feedback" carb. I was going to change to in tank pumps but I'd have to replace both tanks as well. ($$$$$$) Socks are very close if not on the bottom. Could a bad canister or check valves (the little dodads on top of the tanks with the small line from the canister) be plugged up? they both seemed ok when I pulled the tanks.
See Ya,
Moe
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, T-18 but looking for a ZF. 3.55's.
>push much better than they
>suck, so they are supposed
>to be mounted as close
>as possible to the fuel
>tank. On a dual tank
>setup this is kinda difficult.
>You may have to see
>if it is possible to
>retro fit the in tank
>pumps to your tanks, seems
>as tho I read something
>about this on this site
>within the last few days.
I called Ford Racin about the "in tank" fuel pumps and they told me that I'd have to replace the entire tank. I then called a junkyard and they wanted $300 for front and rear tanks with used pumps. After thinking about it there is a fuel return line going back to the tanks. (possible PITA) I meet a guy the other day that came over to pickup some old furniture and he was a mess. (skin was melted and discolored) I asked him what happened and he pointed at my truck and said "You better be careful, I had dual tanks on my truck and I was on fire before I knew it." It was a later model FI truck. Anyway, I'm not gonna mess with "in tank" pumps.
Thanks,
Moe
85 F150 W/95 302HO crate
New AFB
3-sp. C5, Gotta do the AOD thing,
Re-curve dist.
Have you verified that the gas caps are vented, sounds like your pulling a vacuum on the tanks. They will work while there's no room in the tank for air, then as the fuel level goes down the vacuum begins to develop. The next time it does the starvation thing, try taking the cap off and put it back, then see if it'll run.
The other is the filter, is there one you haven't changed?
Jim
>to develop.
I guess I'll double check the caps, I swapped out the locking caps with the original caps awile back and it didn't help. I also replaced the vacuum line from the canister to both tanks...Could it be possible that the canister is causing a vacuum situation from the vent hose on the carb.? I don't see how that is possible, but heck I'm lost anyway...:-)
>The next time
>see if it'll run.
> The other is the
>haven't changed?
I've replaced both "socks" and I have 1 "see thru" up by the carb.
I'm gonna recurve my dist. tonite and check out the original gas caps.
Thanks,
Moe
85 F150
