Fuel pump recomendation
Old Apr 19, 2014 | 04:33 PM
checksix's Avatar
checksix
I have a 1979 F350 with a Holley carburated 460. I’ve installed a custom fuel tank at the rear of the frame and now need to run fuel line and install a fuel pump.
I cannot use the typical engine mounted pump due to lack of space (power steering and AC pump). The tank manufacture recommended a Carter in tank pump but they appear to require fairly complex fittings and a full return system.
I want to avoid that complexity. What are my options? Can I install an electric in line pump outside of the tank? What model is recommended? I do have a regulator to install in the line.
Thanks for the direction!
Old Apr 20, 2014 | 02:51 PM
84espy's Avatar
84espy
Yes, you can install a fuel pump inline. This one should be a low pressure unit. Also, you will want to have an oil pressure cut off signal go to it, so it doesn't keep pumping if you get in an accident.
I know you don't want to mess a mechanical unit, but Edelbrock makes one that supplies 5 psi to the carb, eliminating the need for a regulator. You will love it once it is in. If you remove the oil filter first, the replacement goes much easier.
Old Apr 20, 2014 | 03:26 PM
fmc400's Avatar
fmc400
MSEE
I just finished the writeup for my electric pump conversion. I used a Carter P4070. Here's the thread:
https://www.ford-trucks.com/forums/1...sion-pics.html
Also, very important:
An inertia cut-off switch is what would kill the pump in a collision. An oil pressure cutoff switch only cuts the pump if the engine stops, which may or may not happen. An oil pressure cutoff switch must be installed at a minimum; an inertia switch is a highly-recommended addition.
fmc400
41
Sep 29, 2023 09:46 AM
kr98664
'80-'86 HOWTO's
29
Apr 19, 2019 06:36 PM
bigbird189
Jun 5, 2016 11:49 AM
hallenge
Jan 19, 2016 09:04 AM
gearshift101
Oct 26, 2004 05:12 PM
