What gears do I have?
Old May 11, 2008 | 06:01 PM
mdacton's Avatar
mdacton
Originally Posted by Dave Sponaugle
From what I have read, most of the really weak parts in the E4OD tranny should have been replaced in a factory reman unit as new as 04.
I also know that a lot of the E4OD problems were from people that wanted car shifting from a truck transmission.
Caused problems even when used as a car, downright headaches when used as a truck.
A shift kit and control module upgrade fixed a lot of the excessive slippage and reduced the tranny heat, all good things.
I get a hunt in 2-3 shift sometimes.....
Also not sure if it has 2 or 3 OD clutches, I would like to know whats in it. I have built a few E40d's and clutches were smoked in all of them...If you upgrade a few things to PSD spec it adds some clutches. Makes it spread the load
Old May 11, 2008 | 06:14 PM
David85's Avatar
David85
If you built a few E4ODs, than you should be able to have your peace of mind if you go through the transmission yourself. Thats the only way to know for sure if it is sound. Chances are that most of the factory upgrades were done when the new transmission was built (most after 1995 are good), but the shift firmness is still set for the stock power output of the engine. Adding a turbo means it will slip more when you use the extra power/torque.
SNEWTON
Oct 26, 2008 02:09 PM
tonfro
Feb 20, 2008 04:31 AM
ALL BOY
Jan 8, 2006 04:39 PM
CantDrive55
Apr 24, 2002 05:53 PM
