How do you Decode Differential Tag Numbers?
Old Jan 8, 2006 | 02:35 PM
ALL BOY's Avatar
ALL BOY
Anyone know how to decode the Differential Tag Numbers? Here is what I have:
Top Row: 2 V 125 C
Bottom Row: 5.55 10 2 0B05
Old Jan 8, 2006 | 03:17 PM
76 F-150 390FE's Avatar
76 F-150 390FE
Top Row: 2 V 125 C
you sure that 5.55 aint 3.55 because that is the gear ratio and they never had 5.55 stock but they did have 3.55. what axle is this from?
Old Jan 8, 2006 | 03:26 PM
ALL BOY's Avatar
ALL BOY
I think you might be right. I wasnt sure if that was a 3, or a 5. Looks like its a 3. So what can you tell me about the 3.55 gears?
Old Jan 8, 2006 | 03:39 PM
76 F-150 390FE
what is this in? what engine, tranny, and tires are you running? i am assumeing that this is an 80's 8.8 rear end. if i am wrong correct me.
Mil1ion might be able to help you out a little bit more than i can, he knows the codes pretty well.
Old Jan 8, 2006 | 03:44 PM
ALL BOY's Avatar
ALL BOY
This is on a 1990 F-350 4X4, 5 speed manual, with a 7.3L diesel
Old Jan 8, 2006 | 04:04 PM
76 F-150 390FE
the 3.55s were the stock ratio in most trucks with out a tow package (i believe tow package was 3.73s) if you are useing it as a daily driver and dont plan on putting bigger tires on it then it should be fine. if you do plan on putting bigger tires on it and off roading it you might want to think about a new set of gears. i have 3.50s in my truck with 32s and the acceleration lags and strains the engine from a start going up hill, i am currently looking for a set of 4.11s. do you know how many bolts are on the diff cover? also does it have DRW?
Old Jan 8, 2006 | 04:17 PM
ALL BOY's Avatar
ALL BOY
I have 12 bolts on the rear diff cover. What is DRW?
Old Jan 8, 2006 | 04:39 PM
76 F-150 390FE
ok the rear end is a sterling/ford 10.25. it is a pretty good axle used in the 3/4 and 1 ton trucks then. DRW is dual rear wheels. truck with drw had a dana 80.
Niwrek
Sep 24, 2023 05:53 PM
dcdave
20
Sep 28, 2022 03:25 AM
sunogbahay
Oct 20, 2016 12:53 PM
HANDSOME
20
Oct 27, 2015 08:30 PM
jwhopson
22
Apr 7, 2011 07:22 AM
