Sponsored by: Real Truck
rear diff shutter
Old May 7, 2008 | 08:35 AM
timlewis642003's Avatar
timlewis642003
rear diff shutter
What is the best additive for limited slip rear on 2001 f250. when i have a load i get some shuttering in the rear when turning
Old May 7, 2008 | 10:02 AM
F350-6's Avatar
F350-6
Welcome to FTE. How old is your fluid? Maybe you're due for a change. The additive is called a friction modifier. I believe the book calls for 8 oz. but most start off by adding 4 oz. then more if needed. Too much friction modifier tends to make the LS not work too well.
Some fluids like Royal Purple already have the modifier built in so if you switch to one of those you will not need to add any.
Old May 7, 2008 | 10:26 AM
cartmanea's Avatar
cartmanea
What is your configuration? Depending on if you have a one piece or two piece driveshaft you could need to shim the carrier bearing or it could just be axle wrap.
Old May 7, 2008 | 01:16 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Like Chris said, you might be due for a lube change.
The chattering won't hurt anything...it's just a little reminder that your LS is working.
Too much friction modifier, and your LS won't function like it's supposed to.
Muddinexpedition
Jun 4, 2012 06:01 PM
bangin nails
Feb 21, 2011 05:49 PM
f350rebel
30
Aug 15, 2007 10:05 PM
john63
Mar 25, 2006 03:38 PM
Thumper4995
Jul 11, 2003 01:57 PM
