gas mileage
Old Dec 20, 2000 | 09:40 AM
lanero's Avatar
lanero
gas mileage
Old Jan 28, 2001 | 10:52 AM
nickc84's Avatar
nickc84
gas mileage
Hello All,
85 F-150 302 AOD(thats on its way out) but I'd like to know what to do to make my mileage better, I get like 10 MPG all the time. I did a run and got like 11.5 and that is terrible to me. Its on a 2 barrel Motorcraft carb. What are some of you guys with the 302 getting on mileage and what can I do to make it better? Oil change? Filters? Plugs, Wires, Dis. cap and rotor? And all I have ran in the truck is 93 octane since I have been driving it.
Thanks,
Nick
"Speed equals money how fast do you want to go?"
Old Jan 28, 2001 | 03:20 PM
jopey's Avatar
jopey
gas mileage
85 bronco with a 600 cfm 4 barrel holley
10.5 with a tail wind. but my right foot is heavy too
If it is still running. you didn't try hard enuf!
Old Jan 31, 2001 | 01:27 PM
slikness's Avatar
slikness
gas mileage
I'm running a 351W with Edelbrock 600 cfm and I consistently get 14-15 mpg on long hauls. I've got an MSD 6 ignition w/blaster coil and adjustable timing. I can run my truck at 15-16 degrees advance and then I retard the timing to 6-7 for towing. I run side gapped plugs, Doug Thorley full length headers, Mobil 1 oil, K&N open element filter, and removed as much smog stuff as possible.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Jan 31, 2001 | 05:24 PM
jopey's Avatar
jopey
gas mileage
don;t laugh cause I know there is one wise cracker out there!
302, points and condensor in the ignition part, stock manafolds, K&N open air cleaner. no smog junk. NONE. glass pack for muffler. non-side gapped plugs!
Old Jan 31, 2001 | 05:36 PM
47mercurypu's Avatar
47mercurypu
gas mileage
I am curious as to why you are getting rid of the AOD? I am planning to use one with 351W in restoration.
Old Feb 1, 2001 | 02:30 PM
nickc84's Avatar
nickc84
gas mileage
Well, what are some things that I can do to get my mileage to go up?
and the reason that i'm getting rid of the AOD is cause its old and tired slipping in OD, and rough shifting all the time. so its done. If I were you, i'd get E4OD cause its stronger and better, may be computer controlled but it is definately better than the AOD in my opinion.
Horsepower tv guy the fat one.
Old Feb 2, 2001 | 03:35 AM
lvstang's Avatar
lvstang
gas mileage
>I can do to get
>rid of the AOD is
>its done. If I were
>AOD in my opinion.
>you want to go?"
Simply get the Wide Ratio Kit from FRPP(which is the E40D guts including the lower first gear) for your AOD, add a Lentech manual/auto valve body(which lets you shift a true 1-2-3- pattern with an Electronic OD) and you've got as strong a transmission as anything for around $1000 without trying to figure out the computer controls of an E4OD.
Which I was curious on how you plan to do that????
Aerostar
Aug 21, 2024 11:23 PM
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Mar 11, 2001 10:13 PM
