Sponsored by: Auxito
Dirty Sock Smell
Old May 6, 2008 | 05:36 PM
boatnfish's Avatar
boatnfish
Dirty Sock Smell
'01 Lariat 4X4.
Weather has gotten warm enough the last couple of days to use A/C.
I have noticed that part of the time it will smell like a dirty sock, then goes away for a while.
Any ideas on this? My shoes are on.
Old May 6, 2008 | 05:45 PM
galaxie641's Avatar
galaxie641
A couple of things, always leave the dial on Vent when you turn the truck off. Second turn it to vent for the last few minutes you are in the truck while the AC was running. These things will keep the system drier. If it has bad bacteria/fungus you need to buy one of those spray cans that are suppose to kill everything in the system. I can't remember the name but it is an AC cleaner in an aerosol can. I am sure someone knows the name.
Old May 7, 2008 | 02:07 AM
bamafordguy97's Avatar
bamafordguy97
I had a stale smell in mine when it hit warm weather here in Bama. I cranked the truck. Sprayed Frebreeze down towards the floor and then turned the A/C on full blast and let it run for about 20 minutes. After about 10 minutes and went and repeated the spraying part. LOL Redneckish?? Maybe but it worked. And its been A/C weather for a while around here.
Old May 7, 2008 | 03:09 AM
LxMan1's Avatar
LxMan1
Check the evaporator drain in the firewall to make sure it is not clogged. It should be dripping after the a/c is on for a bit.
Old May 7, 2008 | 05:21 AM
chaser1602's Avatar
chaser1602
Drop the front of the glove box down to see the air intake.Turn the a/c on hi and spray lysol in there
02GrayPowerStroke
1997 - 2003 F150
Jul 27, 2014 10:10 AM
sdemak
2009 - 2014 F150
May 14, 2007 03:28 PM
76supercab
Apr 22, 2002 02:54 PM
jcdye
Mar 9, 2002 07:14 AM
