Safe Egt's
Old May 6, 2008 | 12:37 PM
joe blow's Avatar
joe blow
Safe Egt's
I installed a stand alone gauge set from Quadzilla. No tuner. I have the gauge setup showing EGT/Boost/Coolant/Trans readings.
The digital gauge has the ability to set alarms for particular value setings. I currently have the EGT alarm set (the alarm is basically the temperature populates the entire gauge and flashes). I have the value set @ 1050 degrees.
My question is....what is a safe temperature that a 6.0 PSD can run for a short duration without compromosing the motor?
I have reached the temp a few times when I jump on it and have the pedal mashed (getting on the freeway), but I do not continously run it above 1100....I back off.
Thank you
Old May 6, 2008 | 01:15 PM
UGA33's Avatar
UGA33
The general consensus around here is 1300* for short bursts.
Old May 6, 2008 | 03:50 PM
joe blow's Avatar
joe blow
Ok sounds good. I am nervous to try and puch this 6.0 PSD (piece of ***** diesel). I already had head gaskets.
I am sorry I ever purchased this truck. Sorry Ford Guys
Old May 6, 2008 | 04:15 PM
OZX1's Avatar
OZX1
Check the attachment. Information thanks to bismic, and others...
Old May 6, 2008 | 05:33 PM
joe blow's Avatar
joe blow
I have the probe in the LH exhaust manifold. This is obviously considered to be "post turbo" correct?
If the figures are correct, my truck runs very hot????? Is this right?
I'm confused...like always
Old May 6, 2008 | 05:34 PM
Benchwrench's Avatar
Benchwrench
Great post Ozx,
excellent reference for the towing enthusiest.
Old May 6, 2008 | 05:35 PM
Benchwrench
Pre Turbo Joe,
Post turbo would be in the exhaust downpipe
Old May 6, 2008 | 05:36 PM
Benchwrench
sounds like Your EGT probe is right where it should be
Old May 6, 2008 | 05:53 PM
OZX1's Avatar
OZX1
Yup! On the spot, right where mine is.
Old May 6, 2008 | 08:49 PM
joe blow's Avatar
joe blow
Thank you guys
Old May 6, 2008 | 08:58 PM
brentos's Avatar
brentos
you can hit alot higher than that if needed. you can hold it at 1250 all day no probs and take it up to like 2k if you doing like a truck pull or something. Not recomending it just saying a second there aint going to hurt it. it takes a while for stuff to melt!!!
Old May 6, 2008 | 09:46 PM
joe blow's Avatar
joe blow
sounds crazy. I 'll keep it at average temps.
grandmas77f150
1983 - 2012 Ranger & B-Series
Nov 28, 2010 02:39 PM
whjco
Dec 13, 2008 10:22 AM
bismic
Mar 9, 2008 06:45 PM
jonesy23
Apr 24, 2006 07:37 PM
