header prep questions?
Old May 6, 2008 | 08:34 AM
cjben's Avatar
cjben
I am getting ready to install flow tech long tubes on my 95 5.0 extended cab 4 wheel drive. I have heard the paint on these headers aren't that good,so I would like to strip them and repaint them. what is the best way to do this? I have no access to a sand blaster or any such equipment like that. I am not going for looks when I repaint them,i just don't want them to rust,I am thinking about just using flat black grill bbq grill paint. will this work? what about header bolts and header gaskets? Are the ones that came with the headers good,or should I get others and which ones? thanks!!
Old May 6, 2008 | 08:45 AM
BChance's Avatar
BChance
grill paint won't last any longer than whats on there.. VHT makes a ceramic paint that works marginally well, but is not great either.
This is the best I have found short of getting them coated/plated:
Eastwood Co. - Techline Black Ceramic exhaust coating
Old May 6, 2008 | 10:49 AM
haroldrussi's Avatar
haroldrussi
BChance is correct. Best bet is to get them coated or plated. Better off spending the increase up front and buy them coated. If you already have them try the yellow pages for a coating company in your area....
Old May 6, 2008 | 02:20 PM
bad96's Avatar
bad96
the ceramic coat will rust eventually too, its main purpose is for heat
im with Bchance, ive done the vht header paint and was not happy after i had sand blasted them clean
best bet for the good looks and long lasting is stainless, but pricey
gl
Old May 6, 2008 | 04:27 PM
95F350XL's Avatar
95F350XL
I have the flowtechs. I stripped and repainted still didnt last. Best bet is to wrap them so you dont see them rust. Stainless is the only way to go if you dont want rust. No coating lasts, even good ones.
Old May 6, 2008 | 10:10 PM
86F150302's Avatar
86F150302
Here is the gaskets and bolts I used for my FlowTechs
Mr. Gasket 7660G - Mr. Gasket Header Installation Kits - summitracing.com
I painted mine with grill paint and its been holding up pretty good so far.
Old May 7, 2008 | 07:36 AM
cjben's Avatar
cjben
how long have your headers been on your truck?
1999stroke
Jul 25, 2014 05:41 PM
tjdad62
Sep 10, 2011 11:03 AM
fastmover
N. California Chapter
25
Feb 3, 2008 01:27 AM
Skandocious
106
Oct 30, 2007 08:25 PM
imlowr2
Sep 13, 2005 04:57 PM
