Painting headers
Old Sep 8, 2005 | 08:56 PM
imlowr2's Avatar
imlowr2
Painting headers
I just got a set of Sanderson shortie headers for my truck. They are brand new, however I'm thinking about painting them before installing them. Anyone have good tips on what paint to use and the procedure so the paint will last? I may get them ceramic coated, but don't have the extra cash for it right now.
Old Sep 8, 2005 | 09:10 PM
concretegarage's Avatar
concretegarage
I painted my dragster's headers with high temp flat black paint from VHT. It didn't hold up for even 1/2 the season. I got new SS headers though. I'm planning on trying POR-15 factory manifold gray on the manifolds I'm going to be using in my '55
Old Sep 8, 2005 | 11:32 PM
Randy Jack's Avatar
Randy Jack
Ed -
Like you, I asked around about header paint. The headers that came with my truck were pitted and rusty so they had to get something done. None of the folks I talked to had anything good to say about paint except to buy a lot of it because I would be repainting often.
I had mine ceramic coated by an outfit in LA. Not very pricy (about $200?), but they still look great 3 years later. I wouldn't do anything else, especially if I had new smooth ones to work with. If you need the company info, I can get it for you.
Old Sep 9, 2005 | 07:22 AM
mt54's Avatar
mt54
ED,
I'm not sure if this will be any help , But while lookin on e-bay I saw new ceramic coated headers for small block ford for under $ 200. I know nothing of the quality or anything elce.
Mike
Old Sep 9, 2005 | 08:14 AM
novatattoo's Avatar
novatattoo
I painted my block huggers with high temp paint from Napa. I laid them in the sun to get the metal hot one day. Painted them without primer. So far I only have 12 hours or so run time but they still look perfect. Still like the coated ones better tho.
Later,Bill
Old Sep 9, 2005 | 10:22 AM
imlowr2's Avatar
imlowr2
Well, I did some checking on the ceramic coating. I found a place in Camarillo, CA that coats them for $175.00 with a two day turnaround. I may have to do that. As for ebay, I saw the headers and found several before (trust me, this has been a year long search for headers that fit). I bought these Sandersons on ebay for $114.00 and they actually fit as if they were made for the truck. I've tried just about every other header I can think of, and nothing fit. So I'm excited. I think I better have these coated instead of messing with painting. Sanderson states to put the headers in the oven at 200 degrees. First wipe it down with Acetone, bake it and spray with VHT paint. They claim it will last for a long time? Thanks for the advice guys.
Old Sep 9, 2005 | 12:15 PM
Jag Red 54's Avatar
Jag Red 54
Please let us know the results of the outfit in Camarillo. It sounds like a winner. Thanks, Jag
Old Sep 10, 2005 | 01:47 PM
53fatfndr's Avatar
53fatfndr
If you get them ceramic make sure they get coated inside and out, not just the outside.
As for Sanderson headers, I followed their directions for mine, except I did not use VHT paint. I used Barbeque Grill paint from Lowes. So far, so good. I've heard similar complaints about VHT not working like it should, and have heard better results with BBQ paint.
Old Sep 11, 2005 | 10:18 AM
truckfarmer's Avatar
truckfarmer
Have you looked at the manifold paint from Eastwood or POR-15? I have used the Eastwood paint with good results (all but once, I think my problem though). It needs baked on, either by running engine or in an oven. Have had it last for years.
I don't know the name, but was told by a friend of a place in Jacksonville, Illinois that will ceramic coat a set for $100.
Old Sep 11, 2005 | 10:49 AM
53wa2fl's Avatar
53wa2fl
I am also using the BBQ paint and it is working just fine.
Old Sep 12, 2005 | 08:10 AM
AXracer's Avatar
AXracer
Have them coated, you'll never regret it. How many times are you willing to have to remove/replace them? Painting (or coating) the outside only helps the appearance. Coating the inside will make them last the life of the truck and actually improve performance, headers die from the inside out. Do it now while they are new.
Old Sep 13, 2005 | 02:05 PM
imlowr2's Avatar
imlowr2
I'll take your guys advice. I just took the headers in for ceramic coating.
Jag- You asked on references for coating. I found two places in Camarillo, CA that do the coating. (nearest for me at least in CA, not many places doing this for whatever reason?).
Rewarder Headers
590 E. Constitution Rd
Camarillo, CA 93012 (805) 445-1015
These guys specialize in drag racing headers and boat headers. They want $160.00 for the shorty headers to be ceramic coating. They didn't mention anything about guarantees. They are on vacation right now also...
Xtreme Coatings
270 N. Aviator St.
Camarillo, CA 93010
(805) 388-9983
Specialize in coating of all types. Give a life time warranty against flaking, peeling, etc. They want $150 to do my headers with a two day turnaround. The shop is very clean and the guys are very helpful and knowledgable on the subject. I got a few recommendations from hot rod shops and muffler shops on these guys. I'm taking the header in today for coating. Ask for Allen if you need more info. He's the owner.
I'll let you guys know how the headers come out after they ceramic coat them.
imlowr2
Old Sep 13, 2005 | 04:57 PM
ke6bnl's Avatar
ke6bnl
Rewarder Headers
Xtreme Coatings
270 N. Aviator St.
Camarillo, CA 93010
(805) 388-9983
imlowr2
I also live in the santa clarita area in Agua Dulce and look forward to hear what the outcome of the coating is, my boy who has little money but may still want to coat his doug thorely headers b4 he installs them, in the long run it is a good investment. I did go with
BBQ paint on my shorties on my50 f1 pu and they still look ok but they tend to get chalky. His are for his 70 4x4 chevy pu and it is more of an ordeal to install. But now that he works at a muffler shop we can do things differantly. lets hear back on the results. Ed ke6bnl
nlareau
Jun 1, 2011 06:33 PM
2000f350v10
Modular V10 (6.8l)
Nov 19, 2010 11:47 PM
mrl390
Nov 29, 2006 04:43 PM
Texan1983
16
Jun 29, 2003 08:55 PM
TonyG
Jan 10, 2002 09:14 PM
