Drive shaft vibration
Old May 6, 2008 | 07:50 AM
BeBo03's Avatar
BeBo03
I have a 03 F250 crew cab with a 2 piece drive shaft. From a complete stop while accelerating it seems my drive shaft is vibrating (only until 5 mph). Is this normal since this is a 2 piece drive shaft?
Old May 6, 2008 | 08:12 AM
rbaker6336's Avatar
rbaker6336
no,not normal could be the beginning of a failing u-joint or other components
how bad is it viberating?
Old May 6, 2008 | 08:19 AM
BeBo03's Avatar
BeBo03
Only at take off.
It only happens at take off from a stop sign/light. The vibration may put rippiles in a cup of water sitting in the drink holder put not bad enough to vibrate coins.
Old May 6, 2008 | 08:30 AM
rbaker6336's Avatar
rbaker6336
one goofy thing to check ,make sure rear tire are inflated the same
you didn't mention if two or four wheel drive
Old May 6, 2008 | 08:40 AM
03_PSD's Avatar
03_PSD
i experienced a vibration from take off and then i changed my rear diff. fluid and vibration was gone. i used mobil 1 syn.
Old May 6, 2008 | 11:47 AM
BeBo03's Avatar
BeBo03
New Tires and Oil
The truck is 4 wheel drive. Two weeks ago I put 4 new tires on. 285 / 75 / 16.
Two weeks ago I changed the fluid and used Mobil 1 syn (3.75 qts). However this issue was happening before and after oil change.
Old May 6, 2008 | 12:45 PM
rbaker6336's Avatar
rbaker6336
do you have any lift?could be an angle problem
check u-joints for play and check at slip joint for play
do you hear any squeeks when it viberates?
Old May 6, 2008 | 12:53 PM
kawika's Avatar
kawika
Do you have a lift? It may be the carrier bearing slight off center from drive shaft angle. I have a 6 inch lift and it took me awhile to get it dead center with shims. It's mostly when I power take off when I feel it, otherwise its not there.
Dave..
Old May 7, 2008 | 07:02 AM
BeBo03's Avatar
BeBo03
Bone Stock
The truck is bone stock with 130,000 miles.
Old May 7, 2008 | 07:48 AM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
could be the splines in the 2 piece part where it connects. take it apart and grease the splines. this worked for me but mine was more of a thud when i stopped and went
Old May 7, 2008 | 08:27 AM
Pocket's Avatar
Pocket
Like these guys have mentioned, it could be several things.
Best bet is to start with the easy stuff:
1) inspect the u-joints
2) grease the slip joint
As for the rear differential, does the chatter get worse when you turn sharply at low speeds? If so, then you may need to change the fluid and put in some additive, or the clutch pack could be burned up.
Old May 7, 2008 | 12:52 PM
BeBo03's Avatar
BeBo03
No sounds
No popping, chattering, or grinding sounds when going straight or turning.
Old May 7, 2008 | 02:49 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I suffered with this for 100k miles. I replaced u-joints, I replaced the carrier bearing, then I replaced some more u-joints. Then when I could stand it no more I took the damn thing out, took it to a driveline service shop and $120.00 later I had a like new truck.
68horses
Dec 21, 2014 07:11 PM
BeBo03
18
Feb 3, 2009 07:41 AM
firedudecndn
Jul 11, 2005 09:25 PM
Big D 2
1997 - 2003 F150
Mar 27, 2005 08:09 PM
harold31816
2004 - 2008 F150
17
May 25, 2004 01:20 PM
