F100 accelerator linkage
Old May 5, 2008 | 09:29 PM
Max E's Avatar
Max E
Exclamation F100 accelerator linkage
I finally got my kickdown cable installed for my 302 AOD with a Holley 650. Now I have another problem I hope you all can help me with. I don't have an accelerator pedal in my truck. (54 F 100). Have any of you used a Mustang or something like that for a pedal and did you use a lokar cable with it??
Your help would be appreciated.
Max E
Old May 5, 2008 | 10:29 PM
cmoritz's Avatar
cmoritz
Max Hi!, I used the Lokar in my 55..with the kick-down and throttle cables also.Their pedal has a splined shaft which allows you to adjust it to almost any position..yery nice stuff IMHO. Check-out my gallery, towards the end..for the installed Pic. I also built a small bump-out, so the pedal would be in a more comfortable position,Good Luck!
P.S Dont forget to get your kick-down adjusted with a press gauge at the trans!!!
Jeff and Nicolle
19
Jan 30, 2016 06:34 PM
jlintvet
Dec 28, 2015 07:37 PM
RIKIL
Jul 24, 2015 01:41 PM
hunter301
Nov 12, 2014 07:58 PM
2andfour
Jul 21, 2014 10:36 PM
