289HO heads
Old Mar 25, 2001 | 03:45 PM
nickc84's Avatar
nickc84
289HO heads
Hi guys,
I've just started to rebuild a engine i got for free, I also got a pair of 289 heads, now the guy said that they were 289HO heads, but i'm not positive, could anyone tell me if they are? I got all the numbers off of them, here they are
289
7D27
WF
7E12
C6AE
those are all the #'s off of it. Thanks guys, appreciate it
Nick"Speed equals money how fast do you want to go?"
Horsepower tv guy the fat one.
Old Mar 25, 2001 | 10:30 PM
64 f100's Avatar
64 f100
289HO heads
True Hi-Po heads have one very distinctive feature. There is a boss around the spring cast into the head that keeps the spring from walking. Other features, screw in studs, but anyone can add screw-in studs. No-one can add the raised boss around the valve spring seat. You say you were given the motor and heads. I hope you kissed whoever gave you this kind of stuff. Nice gift if real hi-po heads. Some other feature's of the hi-po engines were a different harmonic balancer, dual point distributor ( not sure if on all ), four barrel intake, hi-po manifolds. There is something about the block but I don't remmember just exactly what it was.
Hope this helps,
Rich
Old Apr 19, 2001 | 11:27 PM
hotrodford_88's Avatar
hotrodford_88
289HO heads
A true hi-po block will also have extremely thick main caps! Also a solid lifter camshaft.
Just a couple of thoughts from a former 66 mustang owner.
1988 F-150, SWB, 5.0 EFI (formerly 4.9 EFI), M5OD 5 speed, 3.08 gears, Summit shorty truck headers, Custom built Flowmaster exhaust system. Force 4 LP6000 lightbar, Federal signal PA-300 100 watt siren, Icom IC-V100 50 watt mobile radio.
1965 F-100 (just purchased 1/18/01), SWB, 390, C-6 auto. Dual exhaust, Not much else to do to it.
Can see both below.
[link:www.geocities.com/hotrodford_88/|Hotrodford_88's Webpage]
Old Apr 20, 2001 | 07:51 AM
Franklin2's Avatar
Franklin2
289HO heads
dogstar
21
Nov 11, 2010 12:39 PM
rmalottwtes30
Oct 9, 2007 12:05 PM
luvinfords
May 16, 2004 04:41 PM
ucmeflyby
Oct 10, 2003 05:46 PM
rednec245
Feb 5, 2003 07:34 AM
