Sponsored by: Auxito
heater problem
Old May 4, 2008 | 08:54 AM
squigler's Avatar
squigler
heater problem
Anybody ever have this i turn the heat **** and the heat still pours out ill have to take it apart and fix it but dont know where to start
Old May 4, 2008 | 09:19 AM
sheetsd66's Avatar
sheetsd66
Sounds like the blend door or blend door actuator. Do a search and you should find what you need.
Old May 4, 2008 | 09:29 AM
squigler's Avatar
squigler
This might sound dumb where and or how do i search?
Old May 4, 2008 | 09:08 PM
yankee7985's Avatar
yankee7985
I would look at the temperature adjustment **** first. Take it off and see if there are any cracks where it goes onto the rheostat shaft. If so, replace it. If the rheostat is loose(shaft is sloppy), replace it. This beats tackling the blend door and is a lot less expensive.
Old May 6, 2008 | 05:10 PM
sheetsd66's Avatar
sheetsd66
Go to the top of the page under ARTICLES/SPECS and hit search.
Old May 6, 2008 | 06:00 PM
steve(ill)'s Avatar
steve(ill)
read this
https://www.ford-trucks.com/forums/6...irections.html
Shadowstalker
Feb 28, 2016 11:35 AM
pennsylvaniabo
Feb 14, 2016 04:38 PM
1prdiva
Mar 23, 2015 08:39 AM
Boilerred73
Apr 2, 2014 12:29 PM
miker73
6.4L Power Stroke Diesel
Feb 13, 2014 09:48 AM
