what is this?
Old May 2, 2008 | 10:29 PM
stacking's Avatar
stacking
what is this?
hey guys,
just wondering if you guys could help me identify a part on my 1994 powerstroke. is all i know is that it is mounted on my diverside fender under the hood, attached to the vacuum disturbution block, and the part is a small 2 inch diamiter cylindar 1 inch thick. one of the hoses, 4 inches long, runs from the disturbution block to this cylinder. also on the cylinder has a low vacuum warning switch pluged into it. im not sure what that cylinder is, and i broke the little nipple off the cylinder that the 4 inch hose connects to while i was taking my heads out. any help on the name and/or funtion of this cylinder is would be greatly appreciated.
thanks a lot guys
Old May 2, 2008 | 10:51 PM
kawa's Avatar
kawa
I don't have a clue what it is or what you are talking about. Can you supply a photo of this animal? If so I'll bet ya it's identified in a heart beat.
Rog
Old May 3, 2008 | 07:41 AM
Cuda_jim's Avatar
Cuda_jim
It's the Low Vacuum Indicator Warning switch. You might be able to bypass it. Just unplug the connector and plug the vacuum line until you get a new one.
It's a normally open switch that closes when ever the vacuum stays below 10 inches of vacuum for more than 7 seconds. When it closes it applies a ground to the brake light.
ford firsttimer
Oct 1, 2021 11:01 AM
ajaxel
Jun 21, 2013 12:55 PM
92cruisinblue
May 30, 2013 01:39 PM
steve(ill)
1997 - 2003 F150
Dec 15, 2005 06:35 PM
a564jim
Aerostar
Nov 28, 2005 11:21 AM
