identify part?
Old May 30, 2013 | 12:28 PM
92cruisinblue's Avatar
92cruisinblue
identify part?
Hey as I was checking vacuum hoses I noticed a small cylinder shaped part under my hood, its on the passenger side, just an inch or so from the fender, all the way back against the firewall, right under the hood, on top of the ac/heat, it looked like it used to have a small hose coming from it but is broken off. It also looks like its connected to a little bracket type thing. What in the world is this? I dont see any loose hoses or anything. Just very curious!
Old May 30, 2013 | 12:58 PM
White 97 xlt's Avatar
White 97 xlt
A picture would speak a thousand words!!!! Got one?? Or maybe a link to one?
Old May 30, 2013 | 01:12 PM
Evan_P's Avatar
Evan_P
Sounds like your talking about this:
92cruisinblue
haha! dont know why i didnt think of that. okay i have the picture. how do i post it on here? i havent done that before im new to the site
Old May 30, 2013 | 01:13 PM
92cruisinblue
yes thats exactly what im talking about! what is the use of that? what am i loosing by not having that vaccuum line?
Old May 30, 2013 | 01:16 PM
White 97 xlt
Full functions of your A/C system...... It closes off the outside air on max A/C...
Old May 30, 2013 | 01:19 PM
92cruisinblue
So is that why my fan only blows when its on high? its like it doesnt even work unless i turn it on full blast. Thanks guys I appreciate the help and info.
Old May 30, 2013 | 01:27 PM
White 97 xlt
Not the only blowing on high would be a "speed" resistor or switch problem..
This vacuum motor closes a door in the air handler box that is normally open ONLY when the MAX air selection (all the way to the left on switch)
That causes recirculation of the air in the cab, normally you are cooling/heating outside air, with it in this position you are recooling the air already in the cab.
Old May 30, 2013 | 01:39 PM
92cruisinblue
Thanks white97xlt! Appreciate the info
Superblue400
Jan 9, 2019 12:16 AM
SGnAZ
Jun 25, 2016 08:40 PM
SIr Arlo
2004 - 2008 F150
Aug 20, 2015 11:09 AM
Eallend7
29
Nov 17, 2012 10:18 PM
Eallend7
15
Nov 6, 2012 08:37 PM
