2001 f350 coilover conversion
Old May 2, 2008 | 07:23 PM
robjs111's Avatar
robjs111
has anydody installed a 2005 and up stock coilover front suspension on a leaf spring superduty ?? if so do u have any pics or details on conversion? thanks.
Old May 2, 2008 | 08:13 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Bet that would ride nice. One helluvan expensive project I bet.
Old May 2, 2008 | 08:17 PM
Izzy351's Avatar
Izzy351
My 2WD came with coil-over sprigs in the front -- I wonder if you could find a way to use the 2WD parts on a 4WD??? Just a thought...
Old May 2, 2008 | 08:39 PM
DCSpecial's Avatar
DCSpecial
They make coilover conversion kits if you are looking for a lift that will allow you to keep your current axles.
03 with Full Traction Coilover Conversion and Kings:
Or, yes you can swap 05+ axles under a 99-04.......heres some axles out of an 06 under what used to be a leaf sprung Excursion:
Of course, if you do the axle swap you can stay at stock height as long as you had the newer stock suspension as well.
Old May 2, 2008 | 08:54 PM
cookie88's Avatar
cookie88
FTE Emeritus
Building the mounting cups for the springs would not be too difficult. One could probably adapt the stock mounts from a 73-79 F-150. The stock track arm would have to be retained, and some radius arms would have to be scratch built. That would be the hard part (for me).
Old May 2, 2008 | 08:59 PM
DCSpecial's Avatar
DCSpecial
If you can find all the stock parts someone took off of a 05-07 to do a 4 link, it's pretty much bolt on (need to drill some holes though).
flamedoutf250
Feb 20, 2020 01:57 PM
Jawing
May 30, 2014 02:16 PM
JBSIXGUNS
Sep 15, 2013 11:24 AM
robjs111
Jun 2, 2008 08:24 PM
