7.3 powerstroke coilover conversion
Old Jun 2, 2008 | 11:40 AM
robjs111's Avatar
robjs111
Has anybody converted the front leaf spring superduty to a 2005 coilover front suspension?? looking to convert over to a coilover setup on my 2001 f350 4x4 crewcab to improve ride?? Thanks.
Old Jun 2, 2008 | 11:44 AM
SOB Racing's Avatar
SOB Racing
I installed a coilover on an 05. when looking for parts i noticed Fabtech has a nice setup for your rig. Look em up. I love my coilover setup 8 inch and i use them all.
Old Jun 2, 2008 | 12:47 PM
robjs111's Avatar
robjs111
did u use stock coilover from 05 and up superduty or custom kit? pics??
Old Jun 2, 2008 | 02:27 PM
rebelchevy02's Avatar
rebelchevy02
If you looked to use the 05 style, youd also need the axle, because the housings are different, and different widths. Otherwise I suppose you could fab up brackets to use the oem 05 style suspension. No I havent done it, just some things you may want to look into.
Old Jun 2, 2008 | 02:39 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
FabTech makes a kit to convert to a coilover suspension, but it is only available with a 6" lift
FabTech Coilover Kit
I think the coilover swap would be cool, I just don't want to lift my truck
Old Jun 2, 2008 | 08:24 PM
DCSpecial's Avatar
DCSpecial
The Full Traction Coilover conversion is a much better product that the Fabtech coilover conversion in terms of superior suspension geometry and construction.
Full Traction 8 Inch 4-Link I.C.G Conversion - Late 1999-2004 F250/350 4wd - 2000-2004 F250/F350 SRW 4wd - Truck Toyz Store
Also available in a 6" lift.
If you are looking for stock height, yes you can swap out the suspension and axles to those of a 05+ truck. You'll get the benefit of the larger brakes, larger unit bearings, better turning of the newer axle.
Jawing
May 30, 2014 02:16 PM
jrockdiddy
Jun 9, 2013 12:11 PM
Gouge Eye
Sep 23, 2012 12:08 PM
RagingBull2k2
Jul 18, 2011 12:07 AM
robjs111
May 2, 2008 08:59 PM
