Does anyone know where I can order a Poison Spyder Dana 60 Kingpin high steer arm pass. side tie rod end?? I've looked everywhere I can think of. The Spyder website is out of stock til September, 4X4online.com just doubled their prices. AARGH!! Any help would be greatly appreciated. Thanks!!
IIRC I bought driver and passenger side for $179 but I ended up no using the driver side. I think the same seller had passenger side only for $89
but it comes with alot more then just the arms
2 Double Shear high steer Arms with Grease Zerk and clamping bolt
8 200,000 psi CrMo ARP high strength studs
8 Custom machined self centering enclosed nuts
2 Kingpin spring / teflon bushing rebuild kits
8 7/8" to 5/8" High Misalignment spacers (propriatary to application)
2 RH QA1 XMR-14 CrMo rod ends & Jam nuts
2 LH QA1 XMR-14 CrMo rod ends & Jam nuts
2 Gr. 8 socket cap bolts for top double shear piece and optional Dedenbear 5 stud knuckle support
