Question...again...sorry
Old May 2, 2008 | 02:43 PM
schlepprock250's Avatar
schlepprock250
Cool...let me know if what you find out.
Old May 2, 2008 | 03:45 PM
Izzy351's Avatar
Izzy351
I've hit 27-28 with both the WW and Stock Wheel. It seems to be harder to get the higher boost numbers with the WW, though. I remember being able to get over 25 pretty easily with the stock wheel (albeit with surge), but I really have to be in it to get to 27 with the WW. And I've hit 1500+ on my EGTs chasing after a gasser Chevy with Nitrous. Kept up, but we both let off -- I let off because of the EGTs. Not sure why he let off. Probably because we were doing over 120...
Old May 2, 2008 | 04:57 PM
schlepprock250
Update!!
ok..after checking evrything I discovered its my uppipes leaking. I had a hell of a time getting them to seat as good as they are. they are leaking at the manifold connection. Oh well im gonna fix tonight so I will let you guys know how it turns out.
Schlepprock
Old May 2, 2008 | 05:12 PM
jhand124's Avatar
jhand124
I can hit 32-34 psi with the early 99 setup, it has to be the smaller turbo spooling up faster. I can do it but I try not to, my bearing is on the way out. I think I have the only ww that surges, hence the bearing going.
Old May 2, 2008 | 11:01 PM
schlepprock250
Well...I havent had a chance to drive it yet but I did find that my buddy left the passenger side (where it connects to the collector) bolts very loose. Got that tightened up and hopefully this is my low boost/high EGT's problem. What do you guys think, could that be the cause of this?
Old May 2, 2008 | 11:30 PM
schlepprock250
Hmmmmm...lol
Old May 3, 2008 | 02:14 AM
orng1's Avatar
orng1
Maybe, it's a good place to start. Check all the exhaust bolts while your at it, oh and the clamps. Best to be sure while your there.
Old May 3, 2008 | 05:44 AM
makomaker's Avatar
makomaker
Sure it could, go over all of your work and double check....reps to you for writing a follow-up.....good job.
Old May 3, 2008 | 09:52 AM
schlepprock250
Update!!
Ok fellas....I had to go get milk and OJ this am. tested my truck and it definately runs smoother and has a better sound than what it did since I tightened up the collector(it was very loose). I posted some questions about how the WW sounded like a coaches whistle.... ya know just not a smooth jet engine style whistle. It sounds right now.BUT.....im still only making 20.lbs of boost....about right? should I unplug the wastegate?what gives?
Thx Schlepprock
Old May 3, 2008 | 11:25 AM
schlepprock250
Ok....I unplugged the wastegate line and plugged it onto a bolt and now I can make 23.lbs of boost....just wanted to post an update. Thx for all the advice and help guys,thats why I love this place!
Old May 3, 2008 | 10:47 PM
mongo75's Avatar
mongo75
Jason how are you getting 34psi on an early 99? I can only get between 27-28 0n mine in the 120 setting, but then again my filter is dirty.....
Old May 3, 2008 | 11:14 PM
jhand124's Avatar
jhand124
I have no idea, but it's at 30+ PSI right away when I hit it from a stop. I can get 25+ psi easily on the freeway when I get on it at 55-65 MPH. I used to have an edge for gauges and tuner and I never saw anything higher than 26 PSI, but I wasn't fooling the MAP sensor either, so I was defueling at the same time. This is also odd because the edge reads the boost from the pcm and our trucks will defuel at 17-22 PSI stock with out a OBA.
I still can't spin my tires on dry pavement with out braking.
