Offroad & 4x4
front lockers
Old May 1, 2008 | 08:03 PM
fballer985's Avatar
fballer985
front lockers
ok, so i have been doing alot of searching and learning for lockers (more specifically aussie locker) to be used in the front of my truck (95 f150 stock).
the main issue is that locker in front and 4wd engaged will b hard to control since if u turn itll want to keep goin straight in snow, but i thought that if u turn w/o using gas, the locker will unlock and act as a regular open diff. so i guess my question is is that if anyone have used front lockers in snow tell me your experience and whether or not the unlock in snow while turning
Old May 1, 2008 | 08:11 PM
littleme13's Avatar
littleme13
in snow ive had them unlock and stay locked all my experiance has said never trust it to unlock. my theory behind this is while you let off the gas the engine is still sending power to the front wheels and with the wheels slipping in the snow there isnt enough traction to slow the tires to unlock the locker.
Old May 1, 2008 | 08:57 PM
MBBFord's Avatar
MBBFord
I have an Aussie Locker in my Front D44, and it works great for me.
No experience in snow, so no comment there, but in the mud it turns very easily when not on the gas.
Even when powering through a turn, as long as there wasn't a lot of traction (mud), it doesn't feel like that much of a strain on the power steering pump, and barely noticable through the steering wheel..
Old May 1, 2008 | 09:01 PM
littleme13's Avatar
littleme13
i forgot to add this as i was trying to chase a 2 year old around. i think either way you will nto be unhappy. it might take some getting used to and you will have to relearn how to steer your truck but the pros outweigh the cons imo.
Old May 1, 2008 | 11:23 PM
Ronin4x4's Avatar
Ronin4x4
This is why a selectable like an arb or ox is your best bet. Because an open diff is your best bet on really slick conditions or trying to make tight turns in snow and stuff. Open when you need it and then fully locked at the push of the butten
Old May 2, 2008 | 07:12 AM
MBBFord's Avatar
MBBFord
ARBs are nice, but with the aussie locker being 1/4 of the price, it's hard to go any other route.
Old May 2, 2008 | 11:55 AM
STGFordCrazy04's Avatar
STGFordCrazy04
with a Detroit and Saggy pump I go where I want in slippery mud. When its not bad mud, why would I be in 4wd?
Old May 2, 2008 | 03:32 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
my bronco has a problem of going straight in nasty mud with tires turned......and its only a L.S.
Old May 2, 2008 | 07:18 PM
STGFordCrazy04
Maybe its the weight of George vs your bronco but I dont have much trouble at all turning in the slippery stuff. In fact I dont have any of the problems normally associated with a locked front diff unless Im on hard ground.
Old May 2, 2008 | 07:41 PM
quadzjr's Avatar
quadzjr
in my case i think its just mainly b/c the spool in the rear......it just hooks up and dont want to stop or turn....front tires are just there for rudders.....
idk......dont bother me to much..
Old May 2, 2008 | 08:17 PM
STGFordCrazy04
detroit in the rear also.
The good thing is detroits will slip slightly every now and then. They arent a 100% lock up like a spool or welded diff.
Nick,
what brand chromo shafts are in your 14B?
Old May 2, 2008 | 08:48 PM
quadzjr's Avatar
quadzjr
yup......
Nick,
superior.......thats why i said im never worried......
Soilman
Offroad & 4x4
15
Jun 26, 2007 12:06 PM
Hans77
Offroad & 4x4
Feb 28, 2007 09:10 PM
superrangerman2002
Oct 5, 2005 09:03 PM
Mud in the blood
Offroad & 4x4
Sep 22, 2004 11:49 PM
78bigbronco
Apr 21, 2003 03:08 PM
