Who's got limited slips or lockers in their D50 or D60 front end?
Hey all,
Looking for advice on putting a LS type unit in my D50 on my '00.
How well does your SD respond in snow/ice with the LS/locker in the front and the Ford unit in the rear?
How about in icy turns? Does the truck want to start drifting?
I'm looking at putting one in the front of my SD, but I fear that it may become similar to brick sliding across a frozen pond with the slightest throttle on ice.
Any reccomendations on a good unit for the D-50?
It would be nice if I could use the existing carrier.
I was kind of leaning to an Electric Locker of sorts so that I could have the best of both worlds.
I have the lockright in the front. Great when you need full traction. I use it to plow.
On the road the big truck does pretty good with 4wd engaged as far as steering pull to either side with accelleration. I only do 30 mph in 4wd. I like the simplicity of the LR.
Detroit in the rear.
Dick
Dick
Up front, for a DD, get a selectable. More expensive yes, but on the road you don't want the front locked up as it can lead to slippin' and slidin'. Then you can use 4WD in icy conditions with the diff open and still maintain some lateral traction or you can lock it up, like 99f350sd, for plowing or off-roading.
I have the ARB's and, like mizzitch said, turning even on loose dirt with it locked is near impossible. I wouldn't recommend a full locker up front in a DD.
That's what I was thinking about having a locked front, it could make it impossible to drive on snow/ice.
Thus the reasoning towards looking at a selectable locker.
It's important to me to keep the beast drivable for the little wife in the winter.
Any reccomendations on what would be a good selectable?
I believe, emphasis on believe, that the only ones who make them for the D50 is ARB and Tractech (Detroit) Electrac.
The ARB is open diff when disengaged, the Detroit Electrac is LS when disengaged.
Really can't go wrong with either, the ARB is nice 'cause you have the onboard air source. The Electrac doesn't require drilling a hole in the diff housing, but it does have an exposed solenoid on the outside.
try this web site http://www.reiderracing.com/ and look at the differentials. I have been looking to do the same. Choices for a dana 60 front include Eaton E Locker,ARB and Electrac.This site has a list of all the availble lockers and LS and
there applications.
there applications.
there applications.
there applications.
Any one heard about OX locker for a D50?
I do know that they have developed a cable type locker for certian axels, and even read that they planned on one for the D50.
I had read some threads on FTE about this very thing.
I'm having trouble finding a site for OX lockers, and the oxtrax.com WS that was mentioned in previous threads is some type of a search engine now.
Anyone know who or where to look for information on OX lockers? Are they even in buisness any more?
What about using a locker for a D44 in a D50, It should fit, right?
